Best (most user friendly) Boost controller??
Old Dec 30, 2008 | 02:19 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Default Best (most user friendly) Boost controller??
Hey guys,
In your opinion, what is the best (not just expensive) electronic boost controller? I need to be able to dial in boost on the fly, have gear based boost, as well as be able to ramp boost over time or rpm.
I also need it to be user friendly, and doesn't take an electrical engineering degree to work.
Old Dec 30, 2008 | 04:35 AM
SuperSpeed's Avatar
SuperSpeed
St. Jude Donor '08-'10
curious to see what is said...i run an eboost 2 but i think that their might be better option out there.
Looks to me like the Eboost2 is a better packaged gauge/controller and the other big player is the Exile EBC which looks to be a little bit better of a controller but its a large box and not a nice small gauge. I would be curious to see what the differences are in the 2 and if anyone has used both. I find my Eboost2 a little complicated to use but there are some good writeups out there.
Old Dec 30, 2008 | 07:05 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Dec 30, 2008 | 07:17 AM
willig72's Avatar
willig72
Default Boost controler
Maybe this will help you. It helped me make up my mind.
http://www.sportcompactcarweb.com/te..._boost_control
Old Dec 30, 2008 | 08:30 AM
AlwaysInBoost's Avatar
AlwaysInBoost
I know you stated that you want an EBC, but I've always been a fan of manual boost controllers. easy to use, cheap and effective. IMO the more features something has the higher the probability something will go wrong with it.. or in other words KISS.
Old Dec 30, 2008 | 08:39 AM
SuperSpeed's Avatar
SuperSpeed
If you want to go with that way of thinking then why not just run off the gate spring? All the features he said a MBC cant do at all..
Old Dec 30, 2008 | 10:07 AM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
DO you want something dual solenoid based?
Brian
Old Dec 30, 2008 | 11:53 AM
AlwaysInBoost
because there is no flexability with running static pressure... that would defeat the purpose of using a boost contoller in the first place.
Old Dec 30, 2008 | 12:36 PM
stainless40cal's Avatar
stainless40cal
Originally Posted by American_HP@Total Perf
Hey guys,
Boost controller???? We dont need no stinkn boost controller just pulleys
You get my package this morning?
Old Dec 30, 2008 | 02:26 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Ohhhhh, But you will my young grasshopper..
Lets just say I have completed my electronic boost controlled KB system.
Cliffnotes:
Infinate boost adjustability up to our maximim boost level, Ability to launch at pre-determined boost settings, ability to ramp boost ANY way you want, and the ability to have gear specific boost....
Basically you get the power delivery of N2o, the controlled boost like a turbo, and the boosting abilities of a PD blower.
Its a 100% plug-n-play system that can be easily adapted to ANY KB C5 or C6.
I designed this system to allow us KB guys to be able to launch at low boost settings, yet have the ability to ramp the boost back in without blowing off the tires.
Finally, at the flick of a switch, you can run the car in either 100% N/A mode, OR in the standard KB blown application.
Old Dec 30, 2008 | 02:56 PM
stainless40cal
Cliffnotes:
Jeff you know i love you right
Sounds like i better just sell my house and give into my boost addiction!
Everything get okay there this morning in the envelope?
Old Dec 30, 2008 | 03:21 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
I honestly didnt check..
Lemme ask my book keeper if she got one. Was it an overnight?
Old Dec 30, 2008 | 03:31 PM
INTMD8's Avatar
0INTMD8
Former Vendor
I used to use innovative/exile but now I really like the Eboost2.
Much more controllable/stable boost. Boost per gear is awesome and it has nice outputs for shift light/etc.
Old Dec 30, 2008 | 03:37 PM
stainless40cal
Yes sir it was let me know!
Old Dec 30, 2008 | 04:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Any pictures of gauge ?
Old Dec 30, 2008 | 09:09 PM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
i am hearing allot about this boost controller from our dealer and close friend
http://www.hksusa.com/categories/?id=1936
you can reed the specs on the left website bar also i understand that only need to dial in boost by PSI and it will do the rest instead of putting percentage of waist gate opening and it will handle the rest
thanks
Old Dec 30, 2008 | 09:40 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Cliffnotes:
That sounds a lot like this system here Am I right?
To Best (most user friendly) Boost controller??
Old Dec 30, 2008 | 09:56 PM
INTMD8's Avatar
0INTMD8
Former Vendor
The Eboost2? Here ya go-
Old Dec 30, 2008 | 10:31 PM
SuperSpeed's Avatar
SuperSpeed
so sounds like my quick debate was settled by someone who has used both. Thanks!
The one thing i dont like about the eboost is setting boost levels by percents and not psi.
Old Dec 30, 2008 | 10:41 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
jim let us all know when u have ur boost by gear set up ready for sale!
