Reduced Engine Power
Old May 13, 2009 | 10:39 PM
Z06wanted's Avatar
Z06wanted
Originally Posted by NICK YOSKIN
u probably have the 1514 set to "no report"
Yes the 1514 code is turned off in my tune. Should I turn it on?
Old May 14, 2009 | 07:05 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I have a copy of his tune and the 1514 table is maxed out at 4.10 in all cells.
Was told by a tuner that the P0101 MAF fail table should have a value of 255 instead of 0 and that's what's causing this, but my car has a value of 0 and I don't have this problem. Waiting for Z06Wanted to change the value and try some launches.
Old May 14, 2009 | 09:52 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
check your throutel wiring , and ur hood is closed corectly both will treger the reduced power comand on the car and will make it go to limp mode
Old May 14, 2009 | 10:10 AM
Z06wanted's Avatar
Z06wanted
It's a Casper wiring harness that is plug and play for a LS2 wiring harness.
Old May 14, 2009 | 10:11 AM
Z06wanted's Avatar
Z06wanted
It keeps raining here also. Can't really do anything.
Old May 14, 2009 | 10:15 AM
user_name's Avatar
user_name
Maxing out the 1514 table did nothing for me. I had to scale the IFR and VE down.
Old May 14, 2009 | 10:44 AM
BLOWNBLUEZ06
with what size injectors?
Old May 14, 2009 | 10:50 AM
user_name's Avatar
user_name
60lbs
Old May 14, 2009 | 11:13 AM
BLOWNBLUEZ06
60lbs
I have 79lb injectors and haven't had to scale anything down and my 1514 table isn't maxed out. I don't get it. I guess I better keep quiet before I start having this problem.
Another problem I noticed with Z06Wanted's tune is that the ETC Scalar is set at .0355. That's going the wrong way for a 90mm from stock which is .0255. It should be .0192. I'm sure that's throwing off calculations somewhere too.
Old May 14, 2009 | 11:48 AM
user_name's Avatar
user_name
What kind of air mass does your pcm see at WOT?
Old May 14, 2009 | 11:51 AM
BLOWNBLUEZ06
I'll have to look at my logs when I get home. I'm running a 2-bar. Are you still running a MAF? The dynamic cylinder air calculations get cut in half when the MAF is removed, so maybe that explains some things.
Old May 14, 2009 | 12:17 PM
user_name's Avatar
user_name
2- bar SD here. With the VE and IFR scaled down 30% I see 1.16-1.2 g/cyl.
Old May 14, 2009 | 01:21 PM
  #33
BLOWNBLUEZ06
Well, he went out and tried it and it still goes into reduced power after changing the P0101 value to 255 from 0. It threw a 1516 code once and just the 1278 code the second time. I still suspect a possible voltage issue due to grounds. We'll see.
Old May 14, 2009 | 03:55 PM
  #34
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
yeah i ran 0 w/o issue...not the problem.
i did though have TB connector issue that would cause intermittent reduced engine power. look at the tangs to see if there is any issues there. also i would have 1514 code issues with my 427 twin turbo. had to "fudge" the ifr and ve table to "fake" the g/per cyl values. doubt that that his issue
Old May 14, 2009 | 04:36 PM
  #35
golfinz's Avatar
golfinz
Theres a guy on the hptuners forum that put his 90mm at .0355 and he doesnt have issues. Z06Wanted, do you have another TB to try out? Thats my guess is something is wrong with the motor on the TB
Old May 16, 2009 | 02:50 AM
  #36
BLOWNBLUEZ06
I threw up a thread there about the ETC scalar. I am just wondering if it throws off other calculations. For the record, he changed the values and it did nothing for him and it is still going to REP. I just found out he has a bad battery. He's going to replace that since we know he needs it anyways. Even though I doubt it will, it would be nice if it made the problem go away. The dynamic cylinder air is 2.58 in one of the cells right before it dies.
The highest value I can find in a WOT log on my car is 1.56
Old May 16, 2009 | 12:03 PM
  #37
user_name's Avatar
user_name
What kind of number do you have in your VE under full boost/peak tq?
To Reduced Engine Power
Old May 16, 2009 | 12:39 PM
  #38
bullitt4110's Avatar
bullitt4110
Ive had a lot of problems with those, they dont crimp the wire good enough and they can come out of the metal clips. I take them apart and soilder all the of connections in the plug ends. Its worth a look.
Old May 16, 2009 | 12:43 PM
  #39
BLOWNBLUEZ06
98. I have my meth maxed out, so I had to take a bunch out of the VE to compensate. The highest value I have in my VE is 127 at 3psi boost, before the meth kicks in.
Old May 16, 2009 | 10:30 PM
  #40
02402ramair's Avatar
02402ramair
It looks like we got Shane's car fixed today. We bolted my slicks up and he made a bunch of dig pulls and it has yet to set the reduced engine power. A good solder and heat shrink connection to the T/B harness and a good IAT sensor makes all the difference. Shane owes me a new set of slicks. lol
Butt connectors on a T/B harness? WTF
