Lots of good info here and I'll add my $0.02. I have always loved the maggie. Even put a maggie hood on my car because I had intentions of installing the maggie. I won't dis the maggie (except the price compared to the power output received). My best friend FunCool has done things with the maggie that few if anyone here has replicated with a PD style blower. I know the cars strengths and weaknesses The centri blower offers a different type of performance which you need to ask yourself what do you want to do with your car? If your HP aspirations are set at a certain level and you want bling as well then look at PD closely. If you want bang for the buck, useable power, flexibility to make power as you mentioned, then go centri..... go to the C5 Z06 fast list and see how many PD blower guys are on the list. All depends on what you want. Based on your comments it sounds as though the maggie will fit your immediate needs but your long term goals will only be filled with a centri.
Ask if anyone has a blower setup near you in Mountain - Prairie section...
Thanks Steve, Wow! I didn't realize there was a Mountain- Prairie section! I'll have to post something up, and see who's around.
Shoulda known this was gonna turn into a Centri. vs PD thread, LOL! Although I'm still talking "out my @ss" cause I don't have either, I think it really comes down more to personal preference. I think for the drag strip Centri would be better because launches would be easier, and more consistent. On the road course it's a crap shoot, you don't need to worry about launching because you're already rolling. With a PD you would need to exercise good throttle control comming out of the slow corners so as not to light 'em up. If yo
I have made a car with Eaton PD before. It was a Beamer E30 4wd 2500 cc and the result was like driving a standard car but with less effort. The power curve was a bit higher than stock all the way from idle to max RPM. That power was usable, like driving a N/A but with more power.
Maybe that's why you're considering a PD. With only 2500 cc, you might have needed the grunt on the low end. With more than twice the displacement, and six gears on the Corvette, it's not much of an issue.
Originally Posted by Vega$Vette
My statement was light to light low end power and torque is going to mean more the peak HP.
Sure, if you don't know how to keep your car in the power band. If you can't do that, NA won't work very well either.
And I'm not saying any of this out of prejudice. I have a roots blower on another vehicle, and it happens to need a big power boost at 2000 rpm. The Vette doesn't.
OK, I'll admit that it might be fun to be able to roll the throttle on at 1500 rpm and light the tires. It just doesn't have much to do with going fast.
As to your question about the difference between Maggie and KB, The Maggie is a "roots" blower while the KB is a "twin screw" there is a difference. Twin screw is supposed to be slightly more efficient.
To the OP....
I have a KB @ 7psi and a very conservative tune. I'm at 507HP at the rear wheels and it's a blast to drive. When I retire in two years, and have the time to fix broken parts, I plan on drag racing the car.
I was torn between the KB and the maggie. I'm old school and to me, a blower goes on the top of the engine. My research led me to believe the roots will tend to fade at higher RPM and the KB will keep pulling to redline. I also thought there would be more room to "grow" with the KB.
Of course, then someone like "funcool" comes along and kicks butt with his maggie. I'll have to wait until I'm racing to see how good my choice was for the track.
But like I said, the KB is a blast on the street..
Good Luck....
I wouldn't call dyno pulls kicking butt!! If the numbers can't correspond to true performance (track results) then the numbers are worthless. When funcool puts down some respectable 1320' numbers then we may more attention to his accomplishments.
Good Luck....
Kicks Butt? I know at least 20 (6 speed) NA cars quicker.
Funtool lives in a small town way up north.
Sorry, I didn't mean to hit a nerve....
I don't know, nor have I ever meant Funcool. I have read some posts about/by him and by saying "kicking butt", I meant he seems to get more power from his maggie than most would expect.
I was just commenting on maggie versus KB, I try to avoid the "my car can beat up your car" debates.
I believe any supercharger is a good supercharger (now don't flame me, I didn't say anything about "best")
Funcool ran 10s with an easy launch and granny shifting. Watch his video!
I ran a mid 11 on a 3000' DA track with PZeros and it was this 1st time at a track for me in 35 years.
That's not "respectable"?
Why do you think GM put a PD on the ZR1?
Because the twin turbo prototype of the ZR1 burnt to the ground. GM then nixxed the turbos and took the easy way out and went PD.
PD blowers are ok. They've been out for 10(?) years now for the C5's and I dont recall one 9 second time slip without the addition of N20.
Centri's and front mount turbos are currently running much faster and have been for a very long time.
It all depends on how fast you want to go. If you're happy with 10's at sea level, make SURE you don't want to go any faster. If you need to you'll either have to add N20 or change your FI method.
There MAY be one or two ZR1's in the very, high 9's soon, but we're talking 1 or 2.. maybe
Take a look at Funcool's HP/TQ numbers and you tell me if 10.9X is respectable. Like I said if the dyno numbers are not applicable to track performance then the numbers are worthless. The soft launch and granny shifting was due to the fact that the power could not be applied to the wheels effectively.
As noted in a previous post,a PD supercharger looks great and has good performance for a street application. However,if you compare all power adders nitrous,turbo's and superchargers the PD supercharger when matched up against another power adder car of comparable HP/TQ numbers it is not competitive...top end (big end) performance sucks.
GM's reasoning for the use of a PD supercharger had nothing to do with obtaining maximum performance levels.
Not really. A supercharger is only going to help you on the straights anyway.
Actually the best mod for road racing is seat time, seat time, seat time, then tires, brakes and suspension.
I agree with you about the track mods. After my first day on the track I realized the brakes on my car were really underpowered. I really think the decision should come down to personal preference anyway. What kind of feel the individual likes when lapping on a road course. Other than that, considerations should be made as to which system will allow him to run safe temps.
[QUOTE=98vettedave;1572171698]Take a look at Funcool's HP/TQ numbers and you tell me if 10.9X is respectable. Like I said if the dyno numbers are not applicable to track performance then the numbers are worthless. The soft launch and granny shifting was due to the fact that the power could not be applied to the wheels effectively.
QUOTE]
Actually FunCool's 10.9X pass was mostly a straight motor run. Both video's he shredded the belt off launch and we only had two belts at the track. Since the Cog he was pushing over 20lbs and lifted a head/blew a frost plug. Pulley change and now running 15-16 lbs. Maggies were never meant to do this but FunCool did it. Maybe it's just proof that the TVS isn't any better than the original maggie Either way its all about the fun. Hopefully next year FunCool will lay it down at the track and run a better #.
To the OP, you need to go for a drive in a FI car with each style of blower and see what turns your crank. At the end of the day you need to do what will make you happy. Good Luck!
I have never driven a PD blown Vette, but I really enjoy my Centri unit. Like others have said the lack of low end is not really a concern of mine. 1st and 2nd gear are useless as far as traction goes. Once I'm in 3rd I can lay the hammer down but around 80-85 the car wants to loose traction if I'm not on a really good road. The car is a beast. I almost bought a Kenne Bell, but after seeing my neighbor having a hard time getting any traction with all the low end torque of his TVS I decided to go a different route. The centri's are also cheaper, less complex, and seem to make more power per # of boost than the PD blowers. I have not confirmend the power per #, but it seems that way to me.
I don't have possibility to test different LS1 chargers because here in Finland we don't have so many of them on our roads..
One friend got 1210 hp/1330 Nm (on the crank) with two turbo's and one got 770 hp/1010 Nm with a centri. None of my friends have KB style supercharger on their Vettes.
Neither of those drive them around the
track but mostly drag racing and one mile challenge.
I would love to drive one mildly tuned C5 with different superchargers around the track..
Take a look at Funcool's HP/TQ numbers and you tell me if 10.9X is respectable. The soft launch and granny shifting was due to the fact that the power could not be applied to the wheels effectively.
Wrong...It was because he did not want to break anything. Anybody looking at the video knows he left at least 1/2 second or more on the table. Better tires a hard launch and power shifting would most likely get a 9.xxx
They wanted great STREET performance and used the PROVEN most trouble free and reliable blower available.
Never seen a centri on a Top Fuel or Funny Car? Oops!
