Engine carnage
Dec 19, 2013 | 07:00 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
WOW! Almost can't believe my eyes!
What were you gonna go with now, can't remember and too lazy to go look to see if it was mentioned?
Please continue to keep us posted!
Thanks,Matt
Dec 19, 2013 | 12:54 PM
Quote:
Originally Posted by
madmatt9471
Thanks,Matt
LM7 Iron block, GM crank,-3cc Forged pistons, Forged H-beam rods with ARP rod bolts. 317 heads, A&A stage 3 blower cam.
Dec 19, 2013 | 12:59 PM
MawneeC5
Why would you choose a blower cam. What kind of compression are you targeting?
Dec 19, 2013 | 01:56 PM
Cruise-In III Veteran
Cruise-In IV Veteran
user_name
It was probably cheap.
user_name
The blower cam isn't too far off from what I was running, just with more exhaust and a higher LSA to remove the overlap. And yea, it was $200
Was running:
228/228 602/602 112 (4 degrees of overlap)
now
228/236 588/602 116 (no overlap)
I don't have a "Target" compression. My compression is whatever my shortblock with -3cc pistons and 317s net with LS9 gaskets. I'll probably have the heads cut .010 just to clean them up. Its going to end up near 9:1
Dec 19, 2013 | 02:46 PM
If you haven't bought the cam yet i would go with something different. 9-1 compression and a late IVC isnt going to be as fun to drive around. I would also get rid of some of the exhaust duration. More exhaust isn't going to be doing that small turbine any favors.
Dec 19, 2013 | 03:30 PM
Cam is already on the way. Heads are at the machine shop
Dec 24, 2013 | 03:50 AM
End of thread
Now on to the build.
Dec 24, 2013 | 04:57 AM
MawneeC5
Don't worry about it. I'm running a cam that would be shunned by internet forums for my setup. 402TT, just shy of 9:1, with 243/251 116lsa adv. 4deg on LSL lobes. In 6th gear at 1700rpm on highway I can throttle it and get 3-4psi. Plenty of grunt down low, and goes nuts up top when it's play time.
Dec 24, 2013 | 11:38 AM
Ooooooooh nice!
Thanks,Matt
Dec 24, 2013 | 01:06 PM
Painful to see that. Good luck getting the car back on the road.
Dec 24, 2013 | 01:12 PM
Lookin good. You going to be back up before the first?
Dec 24, 2013 | 03:28 PM
MVP'S ZO6
Still shooting for that, but its going to be tough since Jegs backordered my head gaskets. They'll get here Friday. AFTER my whole week off is over.
Dec 24, 2013 | 04:48 PM
MawneeC5
Chevy Dealer
Dec 24, 2013 | 04:59 PM
Yep. Two days max usually!!
Dec 24, 2013 | 05:38 PM
