ECS blower build
Old Jan 31, 2015 | 10:26 PM
  #81
blackzo6's Avatar
blackzo6
Do you have to check the alignment on all of these kits or is it just a ecs thing?
Old Jan 31, 2015 | 10:29 PM
  #82
nullpointer's Avatar
nullpointer
All kits should be checked
Old Jan 31, 2015 | 10:34 PM
  #83
StingrayRebel's Avatar
StingrayRebel
I agree that they should all be checked but there does seem to be a trend, I don't hear of guys having many troubles with a&a kits
Old Jan 31, 2015 | 10:47 PM
  #84
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Originally Posted by nullpointer
@schpenxel my understanding of shimming is just using thin washers in the correct location to push (if necessary). Then again that's just a guess because I never had to deal with blower alignments before this
That's what I was thinking too.. I bought a bunch of washers, starter shims and body shims earlier that go down to like 1/64" I think.. SO, hopefully one of those will work out ok
Old Feb 4, 2015 | 11:10 PM
  #85
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Thanks for the input guys, tomorrow I am going to recalibrate the laser alignment tool according to Brets thread. Then I will recheck alignment, remove a spacer and check blower to crank.
How'd the aligning go, if it ended up being needed?
Old Feb 5, 2015 | 07:42 AM
  #86
nullpointer
EDIT: Took some time today to align tool and check pulleys, see below
Old Feb 5, 2015 | 02:36 PM
  #87
nullpointer
I took some time away from work today to align the gates tool to about
3 ft. Using a glass top (level and true according my tools) table, I
placed the tool along the level and used another level to mark the
laser position up close. Then I moved the level back ~3ft and
corrected the laser to match. Hope this is right as it's annoying as
hell to align.
Now to the results
Alt to PS - Top of 2nd rib with a little down valley between 1st/2nd rib
Alt to Crank - Same as Alt to PS
PS to Crank - Top of 2nd (dead on)
Blower to Crank - Top of 1st rib (dead on)
Seems like I need to shim my blow out more. What size shim equals 1 rib?
Old Feb 5, 2015 | 02:49 PM
  #88
schpenxel's Avatar
schpenxel
St. Jude Donor '15
hell to align.
Now to the results
3/32" rib width if I'm not mistaken. May want to confirm that though
Which way does the pulley need to go? Towards front of car or towards rear of car?
Old Feb 5, 2015 | 04:22 PM
  #89
nullpointer
It would seem that the blower would have to come towards the rear of the car as its hitting 1 rib too much towards the front of the car. Sounds like the pulley needs a shim??
Old Feb 5, 2015 | 04:25 PM
  #90
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That's where I was going with it.. adjusting the spacer on the pulley itself instead of trying to move the whole head unit around.
One thing I'd be careful of is I don't remember the bolt that holds the pulley on having a whole lot of threads engaged, even with the original size spacer.. so I'd be careful to make sure there's enough meat there to hold the pulley on with the pulley shimmed out a little bit (if you do increase the spacer size that is)
Old Feb 5, 2015 | 04:33 PM
  #91
nullpointer
Just got off the phone with ECS and they said the adjustable tensioner is used to bring the belt alignment in towards the motor if you have it facing the radiator. No shimming needed for 1 rib off. Now to take a look at the car and make sure I understand them.
Old Feb 5, 2015 | 04:37 PM
  #92
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Interesting. I'll have to think about that one.
I adjusted the angle on my tensioner so that the belt was as close to the center of the tensioner as I could get it (belt was still was towards the rear of it though), so I'm not sure if that was a good or bad idea. I basically leaned the part of the tensioner that touches belt as far towards the engine as I could get it
Old Feb 5, 2015 | 09:17 PM
  #93
a/c man's Avatar
a/c man
Keep up the good work, It looks clean and professional
Old Feb 6, 2015 | 09:17 AM
  #94
nullpointer
Old Feb 7, 2015 | 01:04 PM
  #95
nullpointer
Completed a few smaller tasks today, going to work more tomorrow.
I drilled the intake for the ECS IAT relocation kit, 5/8" in case anyone finds this thread and needs the info. Before I installed the grommet and pushed in the IAT sensor I was worried about it leaking, it was very tough to get the sensor installed. I cannot even spin it in the grommet so this should work nicely.
After that I moved to cutting the MAF pigtail out. Heat shrinking the ends of the 3 wires that I didn't need. I soldered the pigtail on and heat shrinked the connection. Then wrapped it all in painless performance shielding I had laying around. Looks factory.
Next up was to install the restrictor plate
Test fit intake
I did notice the plastic intake bridge did not sit flush with the blower inlet, its impossible to with the filter in place.
This normal?
Also I received my Canbus Triple, more car hacking fun!
Old Feb 8, 2015 | 09:47 AM
  #96
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That looks interesting. What do you have planned?
Old Feb 8, 2015 | 12:43 PM
  #97
nullpointer
Nothing in mind that I want to do, just going to sniff the canbus packets and see what I can play with. I'll make another thread once I see what I have available. If you have any ideas throw them my way.
To ECS blower build
Old Feb 8, 2015 | 06:47 PM
  #98
nullpointer
Worked on some non exciting stuff today
Intake manifold with new brake booster hose and 2 bar map installed
Test fit the intake tube from intercooler to intake manifold
Then moved on to the headers
Passenger side went in very easy (as normal), driver side was a huge PITA. The starter wires and starter always make it difficult. We won and got them installed along with the starter (inc. wiring). I never wrapped the wires as there is enough room around the headers but this time I think I will wrap them.
Used Remflex gaskets with Alper Motorsports header studs to stop the headers from leaking.
This week I plan on installing the holley fuel rails and the rest of the exhaust. I have to figure out how to tee all the lines together so I don't have to run the fuel lines between the rails behind the intake, while utilizing the stock feed line.
Old Feb 8, 2015 | 06:58 PM
  #99
Smoken1's Avatar
Smoken1
Lookin Good!! Your getting alot done for how cold it is there
Old Feb 8, 2015 | 07:36 PM
  #100
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Looking good!
Have you had problems with headers leaking in the past?
On the fuel rails.. which kit did you get? There is one with a few AN fittings and such with it, then there's another with basically just the rails
If you're using the stock line, I would assume the best way is to use a 3/8" OEM to AN converter, then split that to two lines, then run one line to each rail (assuming you don't want to connect the rails)
But, I've never assembled one, so I'm only guessing based on the research I've done so far. I am planning on using Holley rails though. May build a fuel system for mine soon
