ECS blower build
Old May 15, 2015 | 02:38 PM
  #281
nullpointer's Avatar
nullpointer
Originally Posted by FormulaLS1
Well I think my car is done now I hope to grab it Monday or early next week if you want to cruise.
I'm game
Old May 15, 2015 | 09:55 PM
  #282
nullpointer
Results are in
I decided to pull the restrictor plate out, f* it we will do it live.
Mustang Dyno (loaded)
657 rwhp 577 rwtq (for Dynojet fans thats 742 rwhp 651 rwtq).
Old May 15, 2015 | 10:18 PM
  #283
FormulaLS1's Avatar
FormulaLS1
Nice!
Old May 15, 2015 | 11:15 PM
  #284
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Woohoo!
Old May 16, 2015 | 01:40 AM
  #285
StingrayRebel's Avatar
StingrayRebel
awesome!... I knew you would like it without the restrictor
Old May 16, 2015 | 08:46 AM
  #286
nullpointer
haha you were right...it was only making 7 lbs with it in and I didn't do all this work for a measly 7 lbs!
My MAP is reading 13.5# from 5k to redline, but the dyno is at 12.5#. Higher than I wanted but it should live for a while as its fat AFR with low timing esp. for meth.
Old May 16, 2015 | 12:14 PM
  #287
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What is the lower graph from? Before pulling the restrictor or something else?
Old May 16, 2015 | 01:23 PM
  #288
nullpointer
Yes, graph shows the 7 psi and 12 psi pulls. I couldn't make more than 7 psi with the plate in.
Also its worth mentioning I am not the guy wearing purple in the video. He was annoying as hell during tuning trying to get his car worked on at the same time. Zero respect for me as I scheduled my time, and def annoying for the tuner.
Old May 16, 2015 | 10:11 PM
  #289
IH8FORD's Avatar
IH8FORD
that thing is going to be insane on the street. you going to have enough tire to hold the power.
Old May 16, 2015 | 11:09 PM
  #290
4DRUSH's Avatar
4DRUSH
Was his name Paul
Old May 16, 2015 | 11:15 PM
  #291
4DRUSH's Avatar
4DRUSH
You can grind the restrictor plate opening bigger, like 1/16" at a time to get the boost you want.
Good to see everything is working out great for you.
Old May 18, 2015 | 06:41 PM
  #292
Mikes-Z06's Avatar
Mikes-Z06
Good work! Glad to see it turn out well for you, sick ride! My car is there waiting for work to be completed, yellow Z06. Jason has been busy lately. Do you remember, we talked months ago on another thread?
Old May 18, 2015 | 10:42 PM
  #293
nullpointer
Was his name Paul
lol is that the digivet guy with the IIRC purple c5? Talked to him at Carlisle once I think
Thanks, I remember talking but I forgot what you were having done. Cam I believe? Jason has been packed, but is catching up Shoot me a PM when you come to pick up the car and I will stop by.
Old May 19, 2015 | 06:53 AM
  #294
Mikes-Z06's Avatar
Mikes-Z06
Sure thing, I'll message you when I'm there for tuning.
I'd list the parts being installed but not on your thread. It's a common build
Hope your enjoying your ride!
Old May 28, 2015 | 11:04 AM
  #295
nullpointer
I've been driving the car a bit, love it so far! Only issue now is traction. I have 305 R888 on 18" OEM Z06 rims, and keep spinning when I get over 10psi (5k-> redline), which at over 70 mph is a pucker moment. Once it warms up more I will try it again with some psi let out of the tires. As a back up I have some Hoosier DR's on 17" front Z06 rims.
Old Jun 4, 2015 | 10:27 PM
  #296
nullpointer
Intercooler needs more air
Should arrive in 3-4 weeks, going to look killer on a black car.
Old Jun 5, 2015 | 05:35 AM
  #297
romandian's Avatar
romandian
where can you get that?
To ECS blower build
Old Jun 5, 2015 | 09:29 AM
  #298
Jason913's Avatar
Jason913
lg motorsports iirc
Old Jun 5, 2015 | 10:17 AM
  #299
nullpointer
CorvetteMods.com
Old Jun 7, 2015 | 12:17 AM
  #300
nullpointer
Default Transmission is toast
Well I may be down for a while
While driving on the interstate I had a very vicious noise come from the trans while in 6th. Then it happened again, but the car drove normal afterwords. So I made it to the meeting spot but couldn't use 5/6/reverse. When I try to use 5/6 gears the car bogs down and needs much more power to drive, so I quickly stopped using those gears. Reverse makes a wonderful grinding noise and the car doesn't move. 1-4 drives perfectly fine but the car is sitting because I don't want metal ruining those gears.
The trans is a very old stage 4 build RPM unit that I bought second hand many years ago. This trans doesn't even have a serial number due to its age. Going to call RPM on Monday and see if I can get a ballpark $$$.
Bad timing, building a house and expecting a little one in November...
