Intake Opinions
Old May 22, 2017 | 11:31 AM
  #41
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Originally Posted by X2142
I was just about to tell you you'll need rectangular port heads haha, I don't really know the difference in the air flow on rec vs cath honestly. What size throttle comes on the stock ls3 manifold?
90mm on the LS3 also. Supposedly the cathedral ports to this point made more power, but according to my buddy (who's the go-to guy in town, he's one of the smart ones) the new 260 rectangle port AFR's are going to be game changers. That's pretty much how he explained it to me.
Old May 22, 2017 | 12:12 PM
  #42
Volk2142's Avatar
Volk2142
Hopefully he is right. AFR has some damn good heads, I'm looking at some for mine later down the road.
Old May 22, 2017 | 04:17 PM
  #43
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Originally Posted by inspector12
What was your before and after dyno numbers and is the intake the only thing you changed at the time? Thanks in advance.
I will let you know on the 31st. HotRod magazine said in a
comparison of intakes, that the MSD would cut around 35 hp.
We will see.
Old May 22, 2017 | 05:10 PM
  #44
inspector12's Avatar
inspector12
We will see.
Cut or ADD?
Old May 22, 2017 | 05:28 PM
  #45
Volk2142's Avatar
Volk2142
Cut or ADD?
I'm sure and hoping he meant add
Old May 22, 2017 | 05:56 PM
  #46
corvet786c's Avatar
corvet786c
I like the FAST too but its also out of budget for awhile, and I heard it was pain to get it right on the idle. How is it on yours?. I am saving for the ecs at the moment.
Its all in the tune, a mechanic told me once that the Fast 102 was hard to tune on a procharged C5, that I had to get an LS6 intake, until I found the right tuner for it. Mine is great running 8-10 lbs of boost, everything is seated properly and sealed no problems, running with 90 mm LS2 tb.
Old May 22, 2017 | 06:23 PM
  #47
Volk2142's Avatar
Volk2142
Nice well I'm getting the intake before the ecs. I'm wanting to see the difference if any. I'll share the dyno sheets of the new intake. With the LS6 intake I make 378 to the wheel, but I had lost my dyno sheet awhile back.
Old May 22, 2017 | 07:16 PM
  #48
HardcoreABN's Avatar
HardcoreABN
I have decided to go to the LS3 high ram. Planning on going to the 2000hp 417 intercooler in a winter or 3 so I might as well get it now.
Old May 23, 2017 | 08:15 AM
  #49
Volk2142's Avatar
Volk2142
Very high numbers! I hope you get there
Post some dyno sheets?
Old May 25, 2017 | 12:00 PM
  #50
road pilot's Avatar
road pilot
Cut or ADD?
Sorry........ad
Old May 25, 2017 | 04:00 PM
  #51
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
We've been pushing 25+ through a FAST 102 for several years now. No issues at all.
C5Z 9.21@157 shifting gears. 346/TFS220/YSi
Old May 26, 2017 | 08:19 PM
  #52
Drewstein's Avatar
Drewstein
I run LSA heads and LS3, make well over 1200hp. You don't need any expensive intake and I would rather spend the money on a better head to keep it together.
Old May 27, 2017 | 12:52 AM
  #53
Volk2142's Avatar
Volk2142
Yeah I'm not a fan of the 1000 dollar intakes anymore. Did a lot of research and asking around. However I did order the Holley Sniper with the 102mm, the guys at the shop that drag race said the 102mm throttle would be better for a boosted application, if NA then stick with a 92mm until you get over 800rwhp but even then the 102mm isn't really needed then either.
Old May 27, 2017 | 06:19 AM
  #54
stevieturbo's Avatar
stevieturbo
102mm wont make a damn bit of difference on a boosted setup vs n/a
If anything the larger would favour the n/a as it needs every bit of help it can.
Old May 27, 2017 | 01:56 PM
  #55
HardcoreABN
most certainly will once I get the engine back together....shooting for mid June to get a baseline tune in it.
Old May 28, 2017 | 10:41 PM
  #56
Volk2142's Avatar
Volk2142
I can't really argue on it because I truly don't know, I was only told that lol
  #57
Volk2142's Avatar
Volk2142
Nice!
To Intake Opinions
Old May 30, 2017 | 01:11 PM
  #58
Volk2142's Avatar
Volk2142
With your FAST, have you had to change from a drive by wire to drive by cable? All of the FAST, Holley and Atomic throttle bodies are drive by cable. I have yet to see them make a drive by wire. The only drive by wire throttle body that is a 102mm is the Nick Williams for a price more than the intake itself..
Old May 30, 2017 | 01:25 PM
  #59
C5 Pete's Avatar
C5 Pete
AMP Racing
OEM LS2 DBW throttle body.
Old May 30, 2017 | 01:34 PM
  #60
RecMech's Avatar
RecMech
I am just now finishing up my Hi Ram install. Drive by cable conversion has been fairly easy, though I do have ProEFI.
(cable has since been re-routed so it doesnt go thru the windshield!)
