Quick question. Thinking about a stall converter for my twin turbo car. Under normal driving conditions do they build up heat or just when you beat on them. Not interested installing a cooler
I run a basic cheap a$$ cooler on mine , easy to install and not expensive....trans temps fine when driving normal around the city etc....helps at the track a bit as well....I run a 3800 stall though, likely higher than you'll go with a turbo car...
What I have observed with a few vehicles with trans temp gauges is that its mostly load dependent. Under cruise conditions and particularly wiht a lockup type converter, not much higher. But in stop and go city traffic it does go up.
Id get a cooler
Second the cooler. Its when its unlocked that it really builds up heat. Here are some scenarios to consider:
I have a long stretch of rural road to get to the interstate and initial tune it wasnt locking up until 55+ and tranny temps would climb substantially even under light load. I have modified my shifting/lockup tables so that mine locks up at relatively low speeds (45 mph) when lightly cruising.
I watch tranny fluid outlet temp to cooler as well as tranny temp from DIC. The outlet temp is much higher under spirited runs (like at the drag strip) even tho tranny temp shows normal. Without a cooler, you would cook the tranny pretty quickly.
as an example, 4l80e should stay around 160*F I believe. 160-180 perhaps. I've read that anything over 200* cuts it's life in half for every so many degrees or whatever... point was to keep it cool is absolutely the most important part after the quality 9.5" Yank/Vig converter
I run a 3200 stall on my TT vette with a 4L80e. There's no reason NOT to run a cooler. I run a quality Derale trans cooler with a fan mounted right at the radiator inlet duct. Works mint....
Getting ready for a FI 750 flywheel build on my C5 with a RPM Level 7 tranny. Will do an occasional 1/8 mile drag. Want to do a cooler. Is everyone mounting them up front? Also can you suggest some type of line thermostat that will let the fluid get up to temp and not run cold at start up?
My experience is:
If you have an automatic trans, install a external trans cooler period.
I had boosted vettes with 2 external trans cooler back at my shop in TX.
I never like to see trans temps go over 190* even when beating on it.
My experience is:
Thanks for the reply but if you read my post it's a given that I'm doing a cooler. I said"Is everyone mounting them up front? Also can you suggest some type of line thermostat that will let the fluid get up to temp and not run cold at start up?" So my question related to mounting position and thermostat for the cooler. Any input for those questions?
