Cooling
Old 05-28-2018, 04:59 PM
TheBigDog
TheBigDog's Avatar
Default Cooling
You guys running twin turbos what temps are you seeing in 90 degree weather. Considering a Dewitts radiator for my C5. What temp reduction can I expect. Today up to 221 cruising at 65 mph
Old 05-29-2018, 07:05 PM
BMERETR
Keep The Shiny Sine Up
Support Corvetteforum!
BMERETR's Avatar
The fans in our cars turn off at 35 MPH no matter what the temp is and wont re start until you go slower than 35
With HP Tuners you can set the fan on and off speed to something like 200 MPH then the system will work with the temp settings
this solved most of my heat issues
I also run a Twin turbo and have a massive intercooler up front slowing air flow at freeway speeds
TheBigDog (05-31-2018)
Old 05-31-2018, 07:25 PM
TheBigDog
TheBigDog's Avatar
Thanks I did not know that about fans and speed
QUOTE=BMERETR;1597299057]The fans in our cars turn off at 35 MPH no matter what the temp is and wont re start until you go slower than 35
I also run a Twin turbo and have a massive intercooler up front slowing air flow at freeway speeds[/QUOTE]
To Cooling
Quick Reply: Cooling
