Guys, I have a 99C5 with the ECS supercharger and the stock radiator while it works has started to leak a little. My car tends to run a little warm when using the air conditioning does not overheat and based on the gauge reading, my guess is it’s somewhere around 210 but I do have an intercooler in front of it as well as the condenser still but I’d like to upgrade the stock radiator to maybe something a little bigger. I don’t want to go to big as I don’t have tons of extra space but I do have extra space as I could see. What is a good recommendation for it and upgrade to the radiator.? What are you guys using?
I would be interested to know as well. Most will say Dewitts but I would like to know if anyone has had a good experience with another manufacturer? Maybe less expensive...
I don’t even know where to begin with this because I come from the mustang world, so I’m still learning what to use on these cars
Guys, I’ve seen the options a Dewitt’s either the normal version or a cut down version. I do have a supercharger and I know that you can use the stock size by modifying it by lowering it. I’m not sure if mine is already been lowered. Somebody notched the top a little bit. I think they did that in order to clear the supercharger inlet pipe. I also have read about Ron Davis radiators. Are there any affordable that’ll work? I really don’t have $1000 to spend on the radiator but I would like to upgrade the cooling system to lower coolant temps
It was a few years ago and they were on sale. I'd have to look at my invoice but, I'll guess around 1050 give or take. A radiator and fans to fit it I wasn't going to skimp on
so will a stock fan set up not work with the Dewitt radiators?
not without some work You can get thick race radiators of the right size but they might take a bit of \fab
If I were you I'd get a big cheap rad core, drop it down so the blower inlet will fit, and get some separate spal fans
you can make the fan shrouds and make this work with some fiddling
or spend the bucks and drop it in.
i may not feel like messing with it and spend the money once i save up for it.............................are the spal fans a direct plug in to the stock harness/plug and play deal?
If on a budget get a 1-800 Radiator replacement unit. If wanting to go Dewitts alum save up for the matching fan upgrade at the same time, since the cores are much thinker you will want the stronger fans on there.
what is a 1–800 radiator? Where do I look at one of those?
