NEW ATI setup?
I think if everyone who had the kit installed had a good understand of how the engine ran, then were able to run traces on the engine, then understand what they were seeing. I highly doubt that they could be happy with the results...
If one never ran traces on a car with the ATI kit... one would never know how the engine was actually running. Thus IMO, we have a large group of people who can honestly say they are very happy because of the fact that they truly dont know how the car is running.
If you dont remember the results of an ATI kit on a C5, let me refresh your memory.
1. Intake temps through the roof
2. Cooling fan, not cooling properly and prone to failure
3. Idler pulley's burning up
4. Belts slipping
5. 2 or more consecutive WOT runs got the IAT's so hot the engine was pulling timing and reducing HP
6. The elimination of front effective brake ducts
7. The inability of the twin intercoolers to actually cool down in a timely fashion.
8. Too much plumbing, too many bends = heat generation
9. injectors included in the kit which ran over 80% duty cycle.
10. restrictive shroud, blocking 40% of airflow through the rad.
This is what happened on my car as well as others here on the forum.. and when we called ATI to ask about what to do.. we were told "this is the first time we have heard about this" Even months later when new members who just installed the kit had the same problems called ATI... the answer from ATI was the same.. "this is the first time we have heard about this" All I could do was laugh about it while I spent money fixing my ATI kit to what it is today.
So if they have honestly improved the ATI kit... I would really like to see pictures of it... not in the hopes of bashing it... but with the hopes of the kit not causing the problems for the newbies who are purchasing it in the future.
VR
[.....snip.....]
[.....snip.....]
that is not though what i have experienced. i never saw really high IATs during back to back runs on the dyno or street. heat soak has never been an issue with my twins. i never experienced pulled timing. i've been running 21 degrees on one of the earliest stock kits, and my ls1 wanted even more timing. made 495 rwhp with 21 degrees. the car was begging for more timing and would have taken 22-23 degrees easily.
and yes, we spent alot of time on the street tuning the car and datalogging/monitoring.
this is just my experience. maybe my ls1 is a freak, or maybe it is something about the weather in KC. or maybe my tuners/installers put the pimp tune on my ls1. i suspect it is a little bit of "all of the above".
VR
I gave up on this thread because it has come down to politics.
Some here are blinded by their egos. What you just said was a profound recap of the ATI debalce and still you get "Not on mine it didn't."
I'm the guy that if something will work 99% of the time, I'll be the 1%.
I certainly am not game to chance a purchase on a 50% 60% or 70% reliability factor. Hell even a 90% reliability factor when other products are available and better.I hope anyone new to FI and is considering an ATI unit would just think twice before buying the factory setup. Anything with this much controversy can't be good. As they say "caveat emptor."
and there was no "ATI debacle" with my car. and no, mine didn't do what VR described. you seem to be offended that my ATI kit was perfectly fine. or you simply refuse to believe it. whatever. my ATI kit has been great whether you like it or not. get over it.
4. Belts slipping
VR
"8. Too much plumbing, too many bends = heat generation"
thats just plain wrong. more plumbing = cooler air. thats why the rear mounted turbo kits (STS) don't need an intercooler.
"9. injectors included in the kit which ran over 80% duty cycle."
wrong. you want your injectors to be operating at at least 80%. otherwise, you won't get proper spray. 80-90% is the proper range.
with these basic errors, its no wonder that ATI didn't agree with you.
I've never seen either side change their opinion...thus I don't see the point of arguing it any more.
And on a side note, I'd trust VR's experience with cars a bit more than most. I'm not taking sides...just saying that he knows his cars.
What about the folks that don't have a voice on a forum and bought the kit through a magazine ad or internet search and now can't resolve the problems and hate their C5 because of it. Yes we all have a voice here but not everyone participates in these forums. Don't just brush them aside, as you did with VR and Shinobis'z who have personally experienced these problems and only hope to alert new comers to the "potential" pitfalls.
Let's use oversite.
And again, I'm HAPPY for you.
I believe you when you say your car ROCKS! let it go! It's not about you. I don't know you. I've never met you or your car. I have no opinion on your car and it's performance. Have I been clear enough. Crap!
The good news, some tuners have figured it out and still buy the head unit from ATI and make it work better for their clients.
Gee look...NO PICTURES yet. I wonder why? Post the frigg'n photos so the guys that know can comment. That's all HOGURT wanted from the start. and I concur.
"I have the updated size and bearings(got them 10 months ago) not sure if is a newer setup. I hear a chirp at first and then a constant screech. the noise comes and goes.it all looks fine...no lock up.should i be worried?"
Tatooed, care to comment on statistics?
new thread posted
Edit:
"8. Too much plumbing, too many bends = HIGH PSI LOSS"
8b. Requires smaller pulleys to compensate for lost flow, increasing temperatures while compressing more air, compensating for PSI Lost to greater plumbing length and plumbing turns.
Anyone note the poor quality, efficiency and flow rates of the ATI Intercoolers? They become a restriction above 600rwhp.
But can someone specify what exactly ATI has addresses and what is included in their new kit? I'm curious.
Plz, no more politics. The 'original' ATI kits sucked and ATI's Customer Service sucks, but what is New in the 'New Kit'??
You know man... its ok if you are happy with your FI setup. I am happy with mine. I had to spend more to get mine the way I like it. I feel that my Kit didnt deliver like I thought it would, and IMO, that should be ok with you too.
VR
You wrote, "We could play these games all week, but the simple truth is, The problems that have been expressed here can be quite serious and costly. You should acknowledge that at least".
Mello Yellow,
I agree with your 8 and 8b, well said. I think someone may have mentioned it in this thread, but I think ATI has also switched to larger twin intercoolers in their new kit?
I love when threads like this get started. Despite the heated debate, a ton of useful information is always shared on this forum and that's really what I am looking for.
wrt your accusation that i griped about GM, i challenge you to find a post anywhere on any forum where i complain about GM. i went through the oil consumption issues, the repeated column locks, the leaky diffs, the leaky trannys, the plugged AC drains, etc, and i went for months without my car, and had to have the fixes done repeatedly before they were permanently fixed. but i never posted any "i hate GM" or "GM sucks!" or "F GM" comments. and even if i did, i'd drop it after my first comment and move on. i wouldn't keep harping on it for years and trying to discredit GM and run them into the ground. but thats just me.
new thread posted
oh, ok. i read that differently. sounds like you are saying that they should not be running above 80%. they should be at 80-90% to get proper spray. i don't see how 38lb injectors on an otherwise stock car will run at 153% - maybe on a modded h/c car, but then again thats why ATI didn't include injectors in the D series tuner kit.
VR
Your wrote, "
Hogurt,
If you decide to go play down at Rt66 for their test and tune nights (Tuesdays) let me know. I'd like to go head to head and see the difference in gearing".
I would love to. I expect my car to be completed this week, then we will start getting it tuned up. I don't know how long the tuning will take. . .I am not having the car dyno tuned. Instead, we are using team ZR-1 to tune with live readings from the computer. I expect it will take 2-3 weeks to get everything worked out. Then I would love to take a road trip. I too, would like to see the difference in gearing. I will IM you when I find out for sure.
VR
