PTK TT update
Old Mar 15, 2005 | 11:19 PM
  #241
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
[QUOTE=RoadRebel]No, the compressor flow profile on the TE-44 is not to "big". The flow profile just doesnt match the flow requirements spot on.
The more power you make at a given pressure ratio you will move to the RIGHT of the data points I did on the compressor map previously. The dark data point to the right of the sweet spot is based on shinobi's verbal data. The data point to the right of that is the same boost level but made more power, which used more airflow, pushes it further out of the sweet spot. Now, put 402cui and it moves the airflow even further away than that as it will require even more air at the same 9psi.
Now, the exhaust side of that turbo is a different story and Shinobi is finding out.
Phil
well thats why a suffix dr is needed lag is an exhaust side issue. so doc does it seem to you that a hybrid would be best? what other options are out there for t4 exhaust? not gt30r. gt35 is even bigger then te44. te44 come in different configuration? well you know what i can bug you & ask a bunch of hypothetical question but just need to get as close as possible then go for it have endured alot worse things in my life then buying another set of turbos
i hope kevin tries running test tubes and 94, maybe itll suprise us and spool where he wants.
Old Mar 16, 2005 | 08:13 AM
  #242
RoadRebel's Avatar
RoadRebel
Originally Posted by NICK YOSKIN
well thats why a suffix dr is needed lag is an exhaust side issue. so doc does it seem to you that a hybrid would be best? what other options are out there for t4 exhaust? not gt30r. gt35 is even bigger then te44. te44 come in different configuration? well you know what i can bug you & ask a bunch of hypothetical question but just need to get as close as possible then go for it have endured alot worse things in my life then buying another set of turbos i hope kevin tries running test tubes and 94, maybe itll suprise us and spool where he wants.
The TE-44 offer a trim combination Shinobi did not try. He has not posted any dyno graphs so I really cant say how close or far it would be. If my memory serves me you selected a .58 trim with a smaller exhaust trim than his last tested version. The wheel trim will be quite a bit spunkier and with no cats/cutouts it would perform significantly better. But again, Thats only from tidbits of info. If your stuck with them and cant return them why not try them and generate some data. Your still 346cui right?
As for the T3/T4 hybrid..I think you should know the answer to that, look at the TTi stage X.
Phil
Old Mar 16, 2005 | 08:49 AM
  #243
babala65's Avatar
babala65
Originally Posted by RoadRebel
um..346 cui is out of the sweetspot of the TE44 compressor, but not horribly.... but 402cui wont even be in the zipcode..
This of course is my humble opinion supported by limited data supplied by shinobi.
Phil
Phil, what do you think would be the best turbo for my set up?
Old Mar 16, 2005 | 09:51 AM
  #244
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Originally Posted by Bill Reid
I thought "we" had already proven the stock Ti system was pure junk on a turbo setup a year and a half ago. You are not paying for dyno time to prove this all over again are you?
Bill
I don't recall seeing the numbers associated with your testing a year and a half ago, so I asked Mike to tune against the Ti, then see what gain we'd get by going to another exhaust. For me, a major objective of the setup was total stealth, which the Ti accomplished -- but it lost me a lot of torque, and just wasn't worth it.
So this was something I wanted to see for myself on my own car, but to answer your question, I was not paying by the hour on dyno time to figure this out. Of course I did pay for the new exhaust and whatever labor was required to install it.
Sorry, not meaning to hijack the thread. Shinobi, what exhaust are you running on your car again?
Old Mar 16, 2005 | 10:05 AM
  #245
RoadRebel's Avatar
RoadRebel
That "not even in the zipcode" remark was for you .
But, where are the kit mfg and expert at anyways?
Phil
Old Mar 16, 2005 | 12:05 PM
  #246
Shinobi'sZ's Avatar
Shinobi'sZ
Phil
Easy Phil...I could say the same thing about TTi when I was going through the Stage III R&D...and everybody but TTi was responding.
But it is a good question...so hopefully I can give a good answer.
Jose (from Forced Inductions) was too be calling Turbonetics yesterday to see what the availability was on a (T4 flange) BB 50 Trim (54mm compressor wheel, Stage 5 turbine wheel)..I think they wanted to determine whether a .58 or .63 AR would be better for a 346cid, so Jose wanted to talk to the main engineer at Turbonetics about it. I would expect that somebody get back to me today on it. (What your take on this turbo?)
Noob,
I am running the stock 01 cats and some Borla Stingers. When I had the TTi Stage III, Xtreme removed the stock Ti exhaust and put on some Borla Stingers..which aided in eliminating some back pressure and thus made more power. I think this is what Bill Reid is referring too.
The Saga continues...also PTK is building a retrofit heat shield for my headers to help insulate.
Old Mar 16, 2005 | 12:14 PM
  #247
NICK YOSKIN
St. Jude Donor '08
Phil
all forged 8.7 347 cui with stage II lq9
t3/t4 hummmmmmm....
Old Mar 16, 2005 | 12:18 PM
  #248
NICK YOSKIN
St. Jude Donor '08
Phil
Jose Zayes is the expert and told babala65 call him.
Old Mar 16, 2005 | 01:00 PM
  #249
ICULUKN-C5's Avatar
ICULUKN-C5
I thought the purpose of doing a header design was to show the bling like the halltech system.
Old Mar 16, 2005 | 01:05 PM
  #250
Shinobi'sZ's Avatar
Shinobi'sZ
You thought right..it will be a nice polished unit. Good observation.
Old Mar 16, 2005 | 03:01 PM
  #251
flynbludream's Avatar
flynbludream
Something in a T61 looks like it should work for your engine size.
Old Mar 16, 2005 | 03:08 PM
  #252
RoadRebel's Avatar
RoadRebel
Easy? I just dont want to be in here accused of stirring it up and recommending stuff with minimal data. Jose is on LS1tech 24/7 so you would think he would support you here. As for the TTi I believe since you,Bill R and TTi were working on the Stage III that is had plenty of coverage. And, its something that was not reedily available and SOLD allready to customers.
Heat sheild? Tell me more..I am all smiles...
Phil
Old Mar 16, 2005 | 03:21 PM
  #253
RoadRebel's Avatar
RoadRebel
Default t61
Yup,I would agree.The compressor side that would be a good first selection for the bigger cube motor. It targets mathematically at 9,11,13,15,17 and 19psi. The exhaust is something that will need some attention as that a big horse to spin.
Phil
Old Mar 16, 2005 | 05:05 PM
  #254
babala65's Avatar
babala65
O.K. whats A T61? Is it 17 sizes bigger than A TE44? Is it the same flange?
Old Mar 16, 2005 | 05:14 PM
  #255
BigLew's Avatar
BigLew
Default heat shields
So Kevin, you guys smoked any hoods yet!!
Old Mar 16, 2005 | 09:10 PM
  #256
Shinobi'sZ's Avatar
Shinobi'sZ
Yep totally blew it up and it melted to the ground and may car has been reduced to a pile of ashes......come on bro.
The hood is fine, Xtreme just told me that the fiberglass liner was not doing too good...it didn't catch fire...too bad I could have collected my insurance money. Just Kidding
No I told you guys I would be the first to tell you if there were any heat issues..and the fiberglass mat did not take to kindly to the header..so PTK has made a Polished Aluminum cover that will bolt on over the header and provide some additional shielding. I have made a template to vent my hood...very close to JPAS and Toyota's Supra's TRD hood that emiminates under the hood pressure, heat extracts, and helps with down force. But mine is going to look different I have been working on it for about 1 month now. It will be Z06 screened and I think its going to look pretty good. There is also the thermal barrier available. Just don't want to take any chances.
Phil did what do you think about that Turbo size I mentioned.
Old Mar 16, 2005 | 09:37 PM
  #257
RoadRebel's Avatar
RoadRebel
Not enough information, T04B or E cover again?
Was that a super 50? or the regular??
The super is ok, not a ton different than the 60 you allready tried.
The map profile is more horizontal and does have a larger happyzone.
Just overlay some data points on the map as I showed ya before.
Small A/R and the "O"trim or smaller? Its the exhaust side thats killing you more than anything right now.
I like your GT30R suggestion a whole lot better
Phil
To PTK TT update
Old Mar 16, 2005 | 10:32 PM
  #258
Shinobi'sZ's Avatar
Shinobi'sZ
Phil
I don't know really Phil..when I get the info I will post it. I was thinking it was going to be an O trim or what they called a Stage V wheel. I don't think they can get a GT30r in a T4. I am at the mercy of the powers that be.
Old Mar 17, 2005 | 01:14 AM
  #259
flynbludream
If you are going with the GT series anyway it looks like the GT35's would be just about damn perfect for a stock CI setup. I don't know what kind of flanges they fit though.
Old Mar 17, 2005 | 07:32 AM
  #260
babala65's Avatar
babala65
Anyone?
