c5 procharged big problem
Old Oct 14, 2004 | 08:51 PM
MRC5's Avatar
MRC5
Default c5 procharged big problem
i have big problem with my c5 . i cant hit gas hard .. when car makes boost the enging stop runing and make sound like some borken in it . the screen shown SERVICE ACTIVE CONTROL -TCS - REDUCE POWER = i turned the ignition off wait 10 sec. than turn it on . the car start great with no problem ...
what do ya thing
Old Oct 14, 2004 | 09:08 PM
XCELER8's Avatar
XCELER8
Sounds like you had your traction control button on. That happend to me once when I have N20 and left my traction on it shut down my whole car and lite up every light. Turned the car back on and it ran normal. Just make sure you remember to turn the traction control button off. This happens cause the car is getting MUCH more torque than it is supposed to understand.
Jon
Old Oct 14, 2004 | 09:09 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Check the codes and see if you are getting a 1514
Old Oct 14, 2004 | 10:06 PM
MRC5's Avatar
MRC5
Yes It's 1514 Code ....?????????????????????? It's Air Flow ...
How Can I Fix It ???
Old Oct 14, 2004 | 10:09 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Your car needs tuning. Who tuned it after you installed your blower (please tell me it's been tuned )
Old Oct 14, 2004 | 10:16 PM
MRC5's Avatar
MRC5
I Tuned It My Self
Old Oct 14, 2004 | 10:26 PM
DDSLT5's Avatar
DDSLT5
I Tuned It My Self
Old Oct 14, 2004 | 10:33 PM
BlackMagicC5's Avatar
BlackMagicC5
I Tuned It My Self
You need to adjust those parameters. You need to tune it so it does that under more extreme conditions. Do you have any way of knowing what your Air/Fuel ratio is?
Old Oct 14, 2004 | 10:54 PM
MRC5's Avatar
MRC5
No ... I Don't Have
I Sent My Falsh Flie To -pcm For Less- To Fix It .
What Do You Think A Bout It ?
Old Oct 14, 2004 | 11:31 PM
motorokie's Avatar
motorokie
My 99 MN6 did the same thing before Ed Wright tuned it. It dynoed 477RWHP with no other mods. He does mail order tunes as well.
Old Oct 14, 2004 | 11:38 PM
Scubanme's Avatar
Scubanme
No ... I Don't Have
Well...... You got less.
Old Oct 15, 2004 | 12:03 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
No ... I Don't Have
Put your baby on a dyno and dyno tune it. Mail order can get you in the ballpark but if you just dropped a bunch of money on a blower, do it right and get a custom tune. Every car is different, and you don't want to risk blowing your motor.
Old Oct 15, 2004 | 12:56 AM
chriskaw7r's Avatar
chriskaw7r
I Tuned It My Self
If you have LS1 edit change the 1514 calc airflow table X 200% in eng diag section.
Old Oct 15, 2004 | 01:10 AM
mdhmi's Avatar
mdhmi
Mark
Old Oct 15, 2004 | 06:29 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
No ... I Don't Have
DO NOT USE HIS FILE!!!!!!! They do good tuning for LT1's but the worst I've seen for LS1's.I'll garenty motor problems if you use the file they send you.
Old Oct 15, 2004 | 06:30 AM
MRC5's Avatar
MRC5
we don't have a dyno in our country ..i live in saudia arabai and it's so hard to me to send car there .
i'll get air fuel ratio width band to adjust .and test the car by g tech ..thats all what can i do here .
WHAT DO YA ADVICE ME TO DO ???
GOD BLESS AMERICA
Old Oct 15, 2004 | 07:54 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Purchase scanning software and run traces on your car while you drive. This is how some people can tune a car... I know its a lot to have to learn. but in your situation, it may be the only way to do it right.
VR
To c5 procharged big problem
Old Oct 15, 2004 | 08:02 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
GOD BLESS AMERICA
www.fastchip.com
This is Ed Wright he is the only person I know of that can mail order tune your PCM and get it in the real close, the only problem with using him is he locks the PCM so you can't make any adjustments
Old Oct 15, 2004 | 08:41 AM
DDSLT5's Avatar
DDSLT5
VR
Yep - this is the way to go - as you drive the car, you monitor its parameters, and make adjustments until it runs the way you wish. Done right, it is better than dyno tuning! Immerse yourself, learn alot - hey, maybe you can start up a business in your part of the world!
Old Oct 15, 2004 | 09:07 AM
IM QUIKR's Avatar
IM QUIKR
Well I think the topic's been covered well.
I'd just like to add that the tune is the most important part of the install. Bar None.
For anyone else reading this deciding about a SC for their car, if you can't afford a dyno tune by a top rated tuner when everything is complete, don't do it until you can. That is, unless you can afford a new engine. Just my $0.02
Broken belts and pulleys are cheap to replace but a blown engine is a whole other level of maintenance.
