weird problem
Old Feb 16, 2005 | 08:10 PM
Frby98's Avatar
Frby98
Default weird problem
I think I have an electrical problem with my '00.
When the car has gotten warm, and I am sitting still (like at a stoplight), I can hear a high pitched whining noise. It fluctuates up and down at about 1 second frequency (on off in a second). If you look at the radio display, it seems to flicker at the same frequency.
Also, if I hit the power windows (both up even when they are fully up), the lights dim noticeably (including the head lamps), and the voltmeter drops momentarily from 13-14V to 11V. But, it recovers quickly.
I can't see or hear the noise when driving (the wonderful exhaust is too much).
Any suggestions?
Thanks in advance!
Old Feb 16, 2005 | 08:43 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Have someone check out the electrical system; places like Advance Auto will do it. It is normal for the light to dim when placing a heavy load such as a power window to its full-stop position.
The PCM is programmed to slowly raise the voltage output of the generator when a load is applied; and the car is at idle (below about 1K RPM). If it shot the generator up to full power the instant a heavy load is applied, the idle would drop, and in some cars the engine could stall.
However, your drop to 11 volts sounds excessive.
Old Feb 16, 2005 | 11:27 PM
napacruzerc5's Avatar
napacruzerc5
Fuel pump? Can't hear pump when driving because of other noises but you can hear it when stopped. Have read other posts reagarding this.
Old Feb 16, 2005 | 11:30 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Alternator
Old Feb 16, 2005 | 11:33 PM
IllinoisCorvette's Avatar
IllinoisCorvette
Originally Posted by screw991le
Altenator
Most Likely the alt checking out.
Old Feb 16, 2005 | 11:37 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
1. Are you running an amp with your stereo?
2. Do you still have your AC CrapCo Battery?
Never noticed the fuel pump sound fluctuate. It's usually a pretty steady whine.
Old Feb 16, 2005 | 11:40 PM
Dave68's Avatar
Dave68
Altenator
It sure does sound like the voltage regulator (in the alternator) is dying.
NitrousMan's Avatar
NitrousMan
Altenator
Just had the same thing happen in my truck. Voltage would go up and down in it until the regulator in the alternator took a crap.
To weird problem
