Battery Install
Old Mar 25, 2005 | 04:13 PM
duds's Avatar
duds
Default Battery Install
How difficult is it to change out the battery? I have a 2000 with original AC elco and want to change it out with an optima red top. any links out there with step by step instructions? Thanks Duds
Old Mar 25, 2005 | 04:15 PM
2K1 6T8's Avatar
2K1 6T8
Very easy.
No instructions required.
Old Mar 25, 2005 | 04:22 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
- first when removing + last. when installing +first, -last. that's about it
Old Mar 25, 2005 | 04:28 PM
Patches's Avatar
Patches
Disconnest the negative (black) cable first and then the positive cable. Unscrew the bolt holding the hold-down block at the front center of the battery's base. Lift the battery carefully out of the tray, pulling it foward first to clear the lip at the back of the tray.
Check the tray carefully for acid or corrosion that may have leaked out of the battery if it's an older non-AGM or gel-cell battery. If you do find signs of a leak, you'll need to pull the tray and wheel well liner and check the PCM for damage. Cleanup can be accomplished with a baking soda/water solution.
If all looks fine, proceed with the new battery install, reversing the removal of the old battery. Connect the red positive cable first and then the negative. If you're installing an Optima, you may want to contact them and ask about their better hold-down block. They sent me one for free. You can see it in the pic below.
Old Mar 25, 2005 | 04:32 PM
2toys's Avatar
2toys
koooool, I think my wife can handle it. I'm just not good with such technical things. Now if I could just grasp what DIC stands for... I think it's "driver in charge".
Old Mar 25, 2005 | 04:44 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
I installed the 34/78 Sunday and like the others have said, it's easy. If your interested in a nice battery cover they are $13.99 at http://www.batteries.com/productprof...p?appid=320135
Last edited by dadvan99; Mar 25, 2005 at 04:47 PM. Reason: battery cover only fits the 34/78
Old Mar 25, 2005 | 05:16 PM
with what Patches said. It really is very easy. Hardest part is lifing the battery out of the car.
Old Mar 25, 2005 | 05:18 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
34/78 slid right in my 97
Old Mar 25, 2005 | 05:56 PM
BiggieBoy's Avatar
BiggieBoy
Changing a C5 battery is not rocket science. It's about as difficult as changing your shoes and socks.
Old Mar 28, 2005 | 03:48 PM
duds's Avatar
duds
Default Sounds EZ
Thanks for the input.. I did noit realize how EZ the change out is, One other question, what is the diference between the Optime Red top 34-78 and the 75-25? any preferences for our C5's
Old Mar 28, 2005 | 04:05 PM
jman1's Avatar
jman1
not much.... either one will do ya just fine...
Old Mar 28, 2005 | 04:11 PM
terpesman's Avatar
terpesman
I used to have such trouble.... thank god for Velcro!!!
Old Mar 28, 2005 | 05:53 PM
JackTsDBG's Avatar
JackTsDBG
The 34/78 has higher CCA rating - check the Optima site for specifics.
Old Mar 28, 2005 | 05:57 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You guys have all missed the single biggest hazard - I can't believe it!
Don't drop your wrench....if it falls into that black hole under the battery tray, you'll never see it again! I swear that hole goes to infinity and beyond!! And no one ask me how I know this!!!
Old Mar 28, 2005 | 06:01 PM
KOMPNS8's Avatar
KOMPNS8
... it took longer to type + post that reply than it will to replace the battery.
Old Mar 28, 2005 | 06:19 PM
jrose7004's Avatar
jrose7004
If you leave your car running you won't lose your settings!
Old Mar 28, 2005 | 06:41 PM
Steveo1c5's Avatar
Steveo1c5
Just A Note I also will be getting an Optima tonight or tomorrow, I also called Optima and they told me that the 75/35 is no longer, the new number is now the 75/25 same battery. They said 75/25 is the number for a 2001 vette. They must have made some fitment changes.
To Battery Install
Old Mar 28, 2005 | 07:31 PM
DeeGee's Avatar
DeeGee
Never done that
Old Mar 28, 2005 | 08:15 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Get a ratchet closed end wrench, and tie a string around the end of the wrench not used, then tie the other end around your wrist.
Hold on tight to the fender, or you might fall into that black hole and never be seen.
Old Mar 28, 2005 | 08:20 PM
H82GOSLW's Avatar
H82GOSLW
AMEN BROTHER!!!!!!! I thought I was the only knucklehead to do that...although I have you beat. I didn't learn my lesson the first time, I did it on two separate occasions.
