Push Button Start???
Old Oct 10, 2005 | 07:19 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Originally Posted by Mike Mercury
so, you suggest mounting the start button on the floor???
He was talking about what we used to have years ago.. in the 50's.. many trucks I know had floor mounted starters next to the gas pedal... You would push that pedal to start it while also pushing the gas pedal to give it gas... oh yeah.. and we used a HAND choke as well... It was a **** on the dash that you pulled to close the choke on the carb...
The biggest problem was that you could never take it anywhere to get a $250-$400 tune on some Dyno thing...
Old Oct 10, 2005 | 07:30 PM
ZO6vettepilot's Avatar
ZO6vettepilot
It was there once already.... does anybody else remember the old cars of the 20s and early 30s..... key on, (for those with keys) or ignition switch to on, ignition retard lever to retard the spark, throttle lever to about 1/4 - 1/2 travel, pull the choke and press the starter botton on the floor. Cross fingers in hopes that the 6 volt battery was going to turn the engine over fast enough to start. Yes, we really were there once in automotive history.
Old Oct 10, 2005 | 08:01 PM
gtoformula400's Avatar
gtoformula400
Originally Posted by Y2Kvert4me
If you just want a pushbutton to engage the starter, this would be very simple to do. (You'd still have to insert the key and turn ignition on though). I could tell you how to wire this, no problem.
If you wanted to avoid the key completely, that would be more difficult, involve at least one more switch (ignition on/off/acc), and you'd also have to bypass the VATS (key pellet resistor) system...but still not impossible.
You car would be so incredibly easy to steal though, I would absolutely not recommend doing this, and even though I could figure out how to do it, wouldn't share that info.
Thanks Y2Kvertme... you definitly sound like you know what your talking about. If its that much work to set up, and that easy to steal forget it... I wasnt really sure what the process involved or how unsafe it would be, but now I know (thats why I love this forum ) Thanks everyone for entertaining my idea and lending some good info along the way...
-Joe
P.S. Folding Key Fob it is!!!
