[Z06] Battery Dead!
Old Jan 25, 2006 | 03:22 PM
Shylor's Avatar
Shylor
Default Battery Dead!
So I go out to start my 2003 Z06 today and the battery was dead. I currently have a Sears maintainer on it and it has been doing a great job. So I'm not sure what happened here.
I'm about ready to go to Costco and buy a Optima Red top battery, even though I'm still covered under my GM warranty. Not sure I even want another GM battery.
Old Jan 25, 2006 | 03:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get GM to cover it. it may be something NOT battery related and if you kill the redtop,,, I always fault to the OEM warranty. That way you get the problem on paper if it occurs later on down the road after your normal 3/36. most of the time they will work with you.
BC
Old Jan 25, 2006 | 04:12 PM
Shylor's Avatar
Shylor
No it is the battery. C5's have had battery issues since 97, if you don't drive them regularly. The battery is covered under my warranty but I really don't want a dealership touching my car and certainly don't want another GM battery.
Old Jan 25, 2006 | 04:13 PM
hotwheels57's Avatar
hotwheels57
Where I'm at, 2-3 years is about average life span on an oem battery. If you take it to GM, they'll pro-rate it, won't they? It wouldn't hurt to have GM test everything though.
I've got OPTIMA batteries in everything I own. I keep mine charged with a BATTERY TENDER (13.8 volt/1 amp maximum). My longest lasting OPTIMA was still going strong after seven years with that.
Old Jan 25, 2006 | 04:22 PM
Shylor's Avatar
Shylor
Again.....I already stated I use a Sears Maintainer, it's just like a Battery Tender, only cost less. And I do not want those dealership goons touching my car. But I find 2-3 years as an average life span on an OEM battery to be Bull! I have an older Optima Red Top on another car and it is still fine. The more I think about it the more I'm leaning towards just picking up an Optima for my Z06.
Old Jan 25, 2006 | 04:34 PM
Z06_Bob's Avatar
Z06_Bob
Make sure you check the code date on the Optima Red Top if you go that way......several Z06 guys on the other forum have had trouble with recent Red Tops not holding a charge......a quality control issue. I am in the same boat with an '03 and will buy the Odyssey PC925MJT which is a lighter, better battery. FYI.
Z06_Bob
Old Jan 25, 2006 | 05:03 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
red tops are da bomb digity.... I have them in everything I own and have not bought a new battery in 4 years
Old Jan 25, 2006 | 06:53 PM
Shylor's Avatar
Shylor
Well I fully charged up my OEM battery. I drove the car around town today and it seems to be fine. Guess I will have to check it in a day or so. But it's rediculous that these batteries get so run down so fast.
Some of you feel the Odyssey battery is a much better battery than the Optima. I may have to look into that. But where can you purchase them?
Old Jan 25, 2006 | 07:37 PM
Scott03Z06's Avatar
Scott03Z06
Try here http://www.odysseyfactory.com/odybuy.htm
Old Jan 25, 2006 | 07:46 PM
Shylor's Avatar
Shylor
It seems nobody in my city sells them, according to that link. Any big box stores that sell them?
Old Jan 25, 2006 | 07:55 PM
Z06_Bob's Avatar
Z06_Bob
Order from Batterymart.com (they have the best price I have seen).
Z06_Bob
Old Jan 25, 2006 | 08:48 PM
LarryW's Avatar
LarryW
Wow interesting thread!!
That Odyssey PC925MJT has my interest too Shylor
I checked my area and couldn't find anyone real close (San Francisco is about 45 miles away).
Batterymart.com wants 106 bux but then another 22 bux for shipping I'd rather get one locally if I decide to go with this particular battery.
Someone mentioned in another 'battery thread' that Exide (Orbital) is also a good substitution but supposedly they are in a BK Chapter 11 reorg
I have an 04 with about 5300 miles (will be turning 2 this May); I'm wondering if I should buy one of these babies and stick it in my garage and wait for the day that my factory one craps out...
Old Jan 25, 2006 | 09:33 PM
magneto10's Avatar
magneto10
My 2002 Z's battery died in 2004.
The dealer replaced it with an upgraded 72 month delco battery
(not-pro rated)
I would have the dealer replace it and then shop around yourself in a year or two.
Old Jan 25, 2006 | 09:40 PM
pdqz06's Avatar
pdqz06
......yep, battery tender IS the only way to go. i have used them for years, not only on the cars, but my harleys as well, sometimes 6 mos. goes by without starting them.....ZERO PROBLEMS
Old Jan 25, 2006 | 10:51 PM
Shylor's Avatar
Shylor
Yet again, I already had a battery tender type charger on my battery.
Old Jan 26, 2006 | 09:46 AM
bobby777's Avatar
bobby777
Get the AC Delco PRO series 6 or 7 year--non maint. and works great,no problems in 3 years--weighs 34 lbs.
Old Jan 26, 2006 | 04:05 PM
Shylor's Avatar
Shylor
Since the OEM battery is an AC Delco, I am not interested in their products again.
To Battery Dead!
Old Jan 27, 2006 | 03:07 AM
3 Z06ZR1's Avatar
3 Z06ZR1
It's not your battery,no battery will do any better, because your car has a problem. Stock battery's last 6-7 years. Your car is the problem.
Battery tender is not needed. My cars sit for weeks, months at a time.
Ill buy Gm (delco battery's) any time. Support GM, They make the cars we love
Old Jan 27, 2006 | 08:54 AM
Bergs50thAE's Avatar
Bergs50thAE
I just got a battery tender the other day. The directions say red/positive to red terminal post, no problem. Black/negative to the frame on metal on the motor - NEVER hook negative to negative terminal post. Problem - tender wires are only 12" long. Where do you hook the negative??
Old Jan 27, 2006 | 12:01 PM
bobby777's Avatar
bobby777
Hook the neg. to the neg. side battery--never had a problem in 5 yrs.
