Electrical Problem Solved!!! Please Read
Old Feb 3, 2006 | 11:54 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Electrical Problem Solved!!! Please Read
Like the title says, I had a mess, or so I thought. It started as stated in this post.
http://forums.corvetteforum.com/show...221&forum_id=1
I took the code readings with my Predator Handheld Tuner. What a mistake, It was way off and was giving me codes that it pulled out of nowhere. I was getting help from forum member Bill Curlee, who spent a lot of time helping me. The problem turned out to be corroded connections to the right rear wheel sensors. The Predator gave me 49 different codes, none of which were correct. After going through lots of procedures outlined by Bill and still no success. So I tried reading the codes the old fashion way of pressing options and the fuel button 4 times. The only codes that came up was the right rear wheel sensors. So when I told Bill (who did not know that I was reading codes with the Predator) he gave me some simple instructions on cleaning the related connections. BINGO, problem solved. What I want others to know is don’t use a Predator to read codes and do a through search of electrical problems on the forum, before asking for help. The following post by Bill will help with many problems.
http://forums.corvetteforum.com/show...875&forum_id=1
Why this is not a sticky is beyond me. This should be first reading for anyone with electrical problems. I also want to thank Bill for all his help. It is people like him that make this forum what it is. GREAT!!!
Just wanted to tell everyone,
Clayton
Old Feb 4, 2006 | 12:40 AM
Jim Taylor's Avatar
Jim Taylor
I haven't needed any of Bill's advice yet, but I've read several of his posts. It's guys like him that make this forum great.
Old Feb 4, 2006 | 12:55 AM
troy144's Avatar
troy144
Old Feb 4, 2006 | 01:00 AM
Dave68's Avatar
Dave68
This probably hasn't happened to me because I very seldom drive the C5 in the rain. No rain - no corrosion!
Still, thanks for the info; it's good to hear you and Bill solved the problem.
Old Feb 4, 2006 | 05:25 AM
countslav's Avatar
countslav
Bill Curlee is the man......
Just say NO to the rain....
Old Feb 4, 2006 | 06:30 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
The knowledge on this forum never ceases to amaze me. I'm glad you were able to take care of the problem.
Old Feb 4, 2006 | 06:58 AM
csexton's Avatar
csexton
Glad you got her fixed
Chuck
Old Feb 4, 2006 | 08:03 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Bill has been a real help to lots of us.
Old Feb 4, 2006 | 08:06 AM
mhdi22's Avatar
mhdi22
Good reminder/new info for those of us who just didn't know.
Old Feb 4, 2006 | 08:22 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Bill Curlee, is a wonderful member, I solicited a good bit of help from him at the last cruise in.
Chris
Old Feb 4, 2006 | 09:46 AM
DeeGee's Avatar
DeeGee
Bill's a great guy. Never too busy to help
Glad to hear you solved the problem Clayton
Old Feb 4, 2006 | 09:58 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Glad you got 'er fixed. And the forum is a great place with lots of great folks.
Old Feb 4, 2006 | 01:21 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Dave,
Maybe not this problem, but maybe others. Just to be safe, check underneath your battery. By the way, I live in Las Vegas...what's rain?
ps What does HTH mean?
Clayton
To Electrical Problem Solved!!! Please Read
