GM admits Column Lock problem, solution
Old Feb 8, 2006 | 01:12 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default GM admits Column Lock problem, solution
I see where GM has finally admited a potential safety issue in the column lock problem. It certainly took them long enough after all the complaints we've had here on the forum over the years.
They also have dealer instructions for a solution.
Sorry I don't have the link right now but for more information on it, you can go to and click on Forums at the top, then under Corvette Professionals you'll find Keeping Current and the whole article.
I'm just not sure how many people this will affect since so many of us have already had the work done or bought a column lock bypass. But at least the repair is now available at the dealers.
Old Feb 8, 2006 | 01:28 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Sorry but welcome to this year. This recall happened a year and half to two years ago
Old Feb 8, 2006 | 02:01 PM
2KFRC5's Avatar
2KFRC5
Default What's this??
It looks like GM has abandoned the "electronic column lock" with the following Special Policy Adjustment notice:
Subject: GMP06-029 - 05081 Special Policy Adjustment - Electronic Column Lock System
Supposedly, GM is sending notices to owners starting Feb 15. In the notice GM is directing dealers to remove at no cost to the owner the column lock plate on most '97-'04 Corvettes
Anyone know where we can get a copy of this, or more about it?
From a reliable source - - - -
Old Feb 8, 2006 | 02:02 PM
mkiv808's Avatar
mkiv808
Yeah, there's a recall. I'm taking my car soon. Better safe than sorry.
Old Feb 8, 2006 | 02:08 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
MODELS:
1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUAL TRANSMISSION
1997-2000 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION
2001-2004 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION – EUROPEAN EXPORT
VEHICLES ONLY
So am I to understand then that my 2002 A4 does not suffer from this problem and I don't need to concern myself with it?
Old Feb 8, 2006 | 02:13 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I fixed the problem myself. No way am I letting a dealer perform a half-azzed attempt at correcting this. There have been too many stories of the "recall" failing.
Old Feb 8, 2006 | 02:19 PM
carlmorrell's Avatar
carlmorrell
Ahh,
If this is the original recall, it's bull**** of you own a Manual transmission. I had the GM recall done on my car, and got a column lock last week. Just got my CLB module in the mail yesterday.
Old Feb 8, 2006 | 02:25 PM
Gray Ghost's Avatar
Gray Ghost
It's about time they did something. I let them do the original recall, but that didn't cure the problem, it just made the car somewhat safer to drive.
Old Feb 8, 2006 | 02:27 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
After reading it, it's a new recall to completely remove the locking plate.
jeff
Old Feb 8, 2006 | 02:50 PM
2KFRC5's Avatar
2KFRC5
http://www.c5forum.com/cgi-bin/ultim...68.html#000000
Old Feb 8, 2006 | 03:02 PM
S76HeliPilot's Avatar
S76HeliPilot
Sorry, but welcome to today.
DESCRIPTION:
PRODUCT SAFETY #04006C
DATED: FEBRUARY 8, 2006
IMPORTANT:
THIS BULLETIN CANCELS AND REPLACES BULLETIN 04006B, ISSUED NOVEMBER 2004. THE SERVICE PROCEDURE FOR U.S. VEHICLES EQUIPPED WITH A MANUAL TRANSMISSION HAS BEEN REVISED. PLEASE REVIEW THIS NEW INFORMATION IMMEDIATELY.
ALL COPIES OF BULLETIN 04006B SHOULD BE DESTROYED.
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 1997-2004 model year Chevrolet Corvette vehicles. When you remove the ignition key, the electronic column lock (ECL) system prevents turning of the steering wheel. When the vehicle is started, it unlocks the steering. Two conditions can prevent steering while the vehicle is moving:
1. The vehicle is designed so that if the column fails to unlock when the vehicle is started, the fuel supply will be shut off if the driver tries to move the vehicle. If voltage at the powertrain control module is low or interrupted, however, the fuel shut off may not occur and the vehicle can be accelerated while the steering is locked.
2. During quick cranks, the ECL lock pin may not withdraw fully and, in vehicles where there is abnormally low clearance to the lock plate, there may be contact between the pin and lock plate. This can cause a noise or ratcheting when the steering wheel is turned or, if there is insufficient clearance, the steering wheel cannot be turned.
If one of these conditions occurs, a crash could occur without warning.
Old Feb 8, 2006 | 03:06 PM
S76HeliPilot
Originally Posted by JMc
MODELS:
VEHICLES ONLY
They might be assuming you already had the other recall done, which I think on yours removed the plate.
Edited: Sorry US built Auto cars didnt have the ECL instslled for those years!
Old Feb 8, 2006 | 03:09 PM
HummelS's Avatar
HummelS
Automatics produced 2001-04 do not have the column lock.
Old Feb 8, 2006 | 03:12 PM
wstory1's Avatar
wstory1
BlackArrow's Avatar
BlackArrow
Sorry I don't have the link right now but for more information on it, you can go to ModVette.com and click on Forums at the top, then under Corvette Professionals you'll find Keeping Current and the whole article.
Here is the complete bulletin.
MODELS:
VEHICLES ONLY
DESCRIPTION:
IMPORTANT:
CORRECTION:
Dealers are to remove the column lock plate on U.S. and Canadian vehicles equipped with an automatic transmission and U.S. vehicles equipped with a manual transmission. After the service correction, the steering column will no longer lock when the key is removed.
On Canadian and export vehicles equipped with a manual transmission, and export vehicles equipped with an automatic transmission, Dealers are to 1) reprogram the PCM, and 2) verify there is adequate lock plate clearance and, if necessary, replace the lock plate. After the service correction, the steering column will continue to lock when the key is removed.
Refer to the Product Safety Bulletin #04006C for further information.
EFFECTIVE DATE:
Owner mailing is scheduled to begin February 15, 2006.
GENERAL INFORMATION:
Parts required to complete this recall are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO – Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO – Customer Special Order.
The Parts list follows:
Part Number Description Quantity/Vehicle
89023816 Harness Kit, Strg Whl Theft Dtrnt Lk Shorting (US manuals and all automatics except export vehicles) 1
88952428 Wire Kit, Strg Whl Theft Dtrnt Lk (1998-2000 Canadian and export manuals & export automatics) 1 (If Req'd)
26056108 Nut, Strg Whl 1 (If Req'd)
26094767 Plate, Strg Shf Lk (Canadian manuals) 1 (If Req'd)
88964588 Plate, Strg Shf Lk (Export vehicles) 1 (If Req'd)
05694191 Ring, Strg Shf Lk Plt Ret 1 (If
__________________
Old Feb 8, 2006 | 03:15 PM
Zilla's Avatar
Zilla
GM admitted that they had a column lock problem a while back. I was going on info based in his post Also this latest recall replaces the recall that they did in 2004
GR8-LIFE's Avatar
GR8-LIFE
I liked how it took GM 2 almost 2 years to admit they had an oil ring problem in their 2001 models. : Remember when they were telling everyone they were burning oil because they wre gettin on it too hard? Sadly, people actually believed them!
To GM admits Column Lock problem, solution
Old Feb 8, 2006 | 03:21 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
Here is a link to search the National Highway Traffic Safety Admin for any recalls, and yes, this is on there.
http://www-odi.nhtsa.dot.gov/cars/pr...callSearch.cfm
Old Feb 8, 2006 | 03:25 PM
mrC5er's Avatar
mrC5er
Does anybody understand why they would need to install a wire harness if they remove the lock plate? Seems to me that without the plate, who cares if the actuator motor still cycles. Sounds like they're removing the plate and installing an "OEM" column lock bypass at the same time.
Old Feb 8, 2006 | 03:26 PM
bierbelly's Avatar
bierbelly
So, I ordered my CLB today for nothing? Great.
