Burnouts 101.....
Old Feb 16, 2006 | 02:50 PM
DKnapp's Avatar
DKnapp
Can you burn them from a standing start with a 4AT in Comp Mode?
Old Feb 16, 2006 | 09:22 PM
testpros's Avatar
testpros
I have 4.10 rear. Should I start in 1st or 2nd?
Old Feb 16, 2006 | 09:38 PM
Mpwr's Avatar
Mpwr
I use the heel toe method..works great for me!
Old Feb 16, 2006 | 09:48 PM
rgtkst's Avatar
rgtkst
Originally Posted by We Gone
that was gutsy. the trees, the grass, the big rocks close by. did a couple of have any to do with this
Old Feb 16, 2006 | 09:49 PM
HawkIVette's Avatar
HawkIVette
I have a 4.10 also. I use a line lock, and at the drag strip, I do my burnout in second gear. Gets more heat to the tires as they are spinning more RPMs.
Old Feb 16, 2006 | 09:54 PM
bigred6906's Avatar
bigred6906
I have stock gears on my Z06. Should I do it in first or second??
Old Feb 16, 2006 | 10:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Feb 17, 2006 | 01:41 PM
bigred6906's Avatar
bigred6906
should i do it in 1st or 2nd?
Old Feb 17, 2006 | 01:48 PM
mittens's Avatar
mittens
NOT trying to **** anyone off
but if you own a vette, you should know how to smoke your own tires.
I was smoking tires before I had a DL. and if you need to ask what gear go try it in first if you like it and it works then you have your answer if not try second. cars are for fun (at least sports cars) PLAY with them.
but to answer first and second will work, but second is mainly for more heat and a longer roll out. first is easier on parts and takes less effort
Old Feb 17, 2006 | 01:50 PM
1badc5GoStrong's Avatar
1badc5GoStrong
Originally Posted by bigred6906
OK guys......Tell me how you do burnouts......I am curious as to how everyone does it there own specific way.....keep in mind I am on drag radials (they grab quickly and are hard to keep spinning).....Any advice will be appreciated!!!
Line-Lock allows front brakes to remain engaged and rear brakes are released.
Old Feb 17, 2006 | 01:53 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Turn of the TC and power brake the crap out of it! Works every time.
Old Feb 17, 2006 | 02:06 PM
Rhode Warrior's Avatar
Rhode Warrior
There goes about 3,000 miles worth of driving.
Old Feb 17, 2006 | 02:15 PM
  #33
badass1g's Avatar
badass1g
how much is a line lock? and how hard to install?
Old Feb 17, 2006 | 02:23 PM
  #34
rwsr50's Avatar
rwsr50
Someone who wants to turn $400 a piece tires into smoke is worried about how much a line lock costs??? Now that's a good one. Now I've heard it all.
Old Feb 17, 2006 | 03:54 PM
  #35
PolishDude's Avatar
PolishDude
I always wondered if i should do my burnout in first or second, i have a z06, i can do one no problem without even trying but not sure which gear i should keep it in and one burnout is not going to kill your tires, IDM must have done like 20 burnouts on his toyo tires and still has plenty of tread
Old Feb 17, 2006 | 05:05 PM
  #36
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
and with a 3.15 rear axle?
Old Feb 17, 2006 | 05:15 PM
  #37
...Mark...'s Avatar
...Mark...
I just turn the traction control off in my Z. I take off like normal and just mat it once the clutch is all the way out. There is more than enough torque to light up the top half of first and get a good 30 to 40 feet of second. By time i run out second i am going way too fast for city streets anyway.
To Burnouts 101.....
Old Feb 17, 2006 | 05:47 PM
  #38
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
smoke em if you ot em! then do a burnout after!
Old Feb 17, 2006 | 06:00 PM
  #39
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Default Z06-JIM Teaches Us
Here's a link to a tutorial on burnouts produced by Y2Kvert4me and featuring Z06-JIM Jim is sort of self taught as this tutorial will show
http://forums.corvetteforum.com/show..._id=103&arch=1
Old Feb 17, 2006 | 06:10 PM
  #40
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I'm sure Jim will be just thrilled to see that posted again.
