Burnouts 101.....
Old Feb 16, 2006 | 01:54 AM
bigred6906's Avatar
bigred6906
Default Burnouts 101.....
OK guys......Tell me how you do burnouts......I am curious as to how everyone does it there own specific way.....keep in mind I am on drag radials (they grab quickly and are hard to keep spinning).....Any advice will be appreciated!!!
Old Feb 16, 2006 | 02:03 AM
COLORADO FRC's Avatar
COLORADO FRC
Put in a line loc, you can smoke'em all day!
Old Feb 16, 2006 | 05:15 AM
Shane_S's Avatar
Shane_S
It's all about the roll control module
Shane
Old Feb 16, 2006 | 06:08 AM
mhdi22's Avatar
mhdi22
ya... my first playing around...I thoought the Vette would act like my Super Bee...Traction control took care of that thought...It stalled right out once I held the brake and tried to increase the rpm...ha. And I thought it would be east to spin those tires...computer said no.
Old Feb 16, 2006 | 06:45 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Send me your tire money, I'll send you some smoke! You rich people!
BTW what are all you guys doing up so early? Green dots everywhere.
Old Feb 16, 2006 | 07:02 AM
HemiKLR's Avatar
HemiKLR
Ya, I wish i had the money so spin em. And I haven't gone to bed yet from Wednesday night.
Old Feb 16, 2006 | 07:11 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old Feb 16, 2006 | 07:59 AM
Dark-Knight's Avatar
Dark-Knight
Just a little bit of gas and pop the clutch!
Old Feb 16, 2006 | 08:07 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
so easy
1. Make sure the car is in Comp Mode otherwise the car will stall
2. try to get your DRs wet - if they are cold you should not have a problem
3. Rev engine to about 3-4K
4. drop clutch (do not and I repeat - do not ride the clutch - let it out all the way - right away)
5. move your clutch foot over to the brake and lightly push the brake down to lock the front tires
6. watch your RPMs to make sure that you stay in the 5K+ range without hitting the rev limiter.
7. when done slowly take your foot off the brake and then the gas to allow the car to roll out. When you slow down push the clutch back in.
As a reminder at the end of the burnout with everything still spinning really really fast you do not want to push that clutch in. Things will break.
FYI - if you car does not have the DTE brace or the hardened output shaft I do not recommend doing burnouts with DRs especially DRs that are dry or somewhat heated.
That being said light them up
Old Feb 16, 2006 | 08:23 AM
Billdog350's Avatar
Billdog350
This was done on a closed course, by an experienced driver (me).
http://www.speedfreaks-ct.com/uploads/Burnout.mpg Just right click and download because the server doesn't stream too well.
The belts had broken in the sumitomo crap tires that I had on there and it was time for new ones, but these still had over 1/2 tread left!
Old Feb 16, 2006 | 11:58 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
you didnt mention that it was camaro not a vette
Old Feb 16, 2006 | 12:03 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I just push the gas pedal to the floor.
Oh...you meant from a stop
Peace
Willfulone
Old Feb 16, 2006 | 12:06 PM
Elpelon's Avatar
Elpelon
I don't.
At $1300 for a good set of tires you apparently have more money to burn than tires
Old Feb 16, 2006 | 12:09 PM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
After a weekend of , I'm usually a burnout on Monday..works every time.
Old Feb 16, 2006 | 12:44 PM
bigred6906's Avatar
bigred6906
Originally Posted by Wicked Weasel
so easy
When I move my foot over fromthe clutch to the brake.....i have to push the brake softly right? If i just hit the brakes really hard the car will stall wont it?
Old Feb 16, 2006 | 12:46 PM
Billdog350's Avatar
Billdog350
Pressing the brakes just enough to keep the car from moving is all you need....any more and you're fighting the engine, as well as causing undue wear to your rotors and brakes.....
Old Feb 16, 2006 | 01:02 PM
dbirdz06's Avatar
dbirdz06
Have fun
To Burnouts 101.....
Old Feb 16, 2006 | 01:16 PM
DOUG @ ECS's Avatar
DOUG @ ECS
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
remember, no reverse burn outs
The rear is not designed for abuse in that direction (as much) so it is easy to couse problems that way.
Old Feb 16, 2006 | 01:18 PM
Wicked Weasel
Originally Posted by Elpelon
I don't.
OMG people are getting on someone's case for asking how to do a burn out. I could see if he was wasting your money, but WTF it is his money and he can spend it however he wants.
BTW - $1300 is for 4 tires not just the 2 rear ones. If you are spending $1300 for 2 tires then who is wasting money?
A set of rear BFG DRs that were made for the 1/4 mile and for burning out cost $300.00 so he can do this 4 times for what you spend on tires and still have $100 left for gas.
Old Feb 16, 2006 | 02:44 PM
wstory1's Avatar
wstory1
