Tread depth
Old Mar 23, 2006 | 10:46 PM
az57chevy's Avatar
az57chevy
Default Tread depth
The old timer advice was when you stuck a penny in the thread and could see all of Abe's head it was time to replace the tires. Is this still accurate for GY Run Flats or how far down is safe?
Old Mar 23, 2006 | 11:40 PM
Dave68's Avatar
Dave68
Technically, replacement is recommended when the wear bars are even with the threads. Realistically, the closer you get to bald, the more dangerous driving is in the rain. If you never drive in the rain, you can wear them down to a "Hey, your tires are bald, mister" depth before trashing them for new ones. I got rid of my runflats at 16,000 miles, went to non-runflat GSD3s and never looked back. The difference is amazing.
Old Mar 24, 2006 | 12:22 AM
DeeGee's Avatar
DeeGee
2mm thread in my experience
Whats that in inches?
Old Mar 24, 2006 | 06:36 AM
They say to replace tires when the tread depth is down to 2/32nds - but, when you get down to around 4/32nds things can get pretty slippery. When I had my original EMTs on the car, traction was a problem at the 4/32nds level. Not sure where that placed it on the penny scale.
Old Mar 24, 2006 | 06:38 AM
spdislife's Avatar
spdislife
A sixteenth of an inch maybe
Old Mar 24, 2006 | 06:41 AM
RebelVette's Avatar
RebelVette
Not enough...
Old Mar 24, 2006 | 10:54 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
2/32 in. or 1/16 in. or 4/64 in. or .0625 inch. which ever comes first
Old Mar 24, 2006 | 12:02 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
You can pick up a tread depth guage at any pepboys for about 3 bucks. Most tires should be taken off at about 2/32nds. The EMT's are pretty well shot at 10/32nds.
Old Mar 24, 2006 | 12:34 PM
girl-ina-box's Avatar
girl-ina-box
St. Jude Donor '05
I have the original tires at 15k....should I be thinking about new ones?
Going to try the penny thing and will take a picture for your input.
Old Mar 24, 2006 | 01:05 PM
girl-ina-box
St. Jude Donor '05
omg it's dirty!
This is the right rear....didn't know which tread to insert it in.
Old Mar 24, 2006 | 01:14 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Originally Posted by girl-ina-box
omg it's dirty!
Put it in the shallowest part. Looks like you're in good shape.
When I got rid of my runflats, there was plenty of tread on one side, and the cord was showing on the other side. Badly misaligned ... I should have checked more often!
The only thing dirty on that car is the tire tread ... can't keep that clean unless you never drive it at all.
Old Mar 24, 2006 | 01:24 PM
edensknight's Avatar
edensknight
omg it's dirty!
Great photo, "GIB". Depending upon the brand, model, and, application, most "street" tires start life with 9/32 to 11/32 of tread depth, brand new. Now, if you look closely at this specific photo of yours, you will see a raised embossed Triangle Tire Emblem. In the tire industry, these triangular tire emblems are molded onto the outside shoulder edge of a tire, and, help to allow any consumer to locate the raised, rounded horizontal rubber bars called Tread Wear Indicators. These Tread Wear Indicators are located throughout the surface of the tire, directly across from the triangular emblems, and, are generally at a height of 2/32 of tread depth. In general, you NEVER want to allow your tire to be worn so far down that you actually begin to wear down these Tread Wear Indicators.
Old Mar 24, 2006 | 01:32 PM
girl-ina-box
St. Jude Donor '05
Hi Gary
EK---I learned something new today!!!!
Never knew what that triangle was for....to be honest, never even knew it was there!! Thank you for sharing that!!
Great forum this is!!!
Lori
Old Mar 24, 2006 | 01:54 PM
Evil-Twin's Avatar
Evil-Twin
EMT's have wear bars...
Old Mar 24, 2006 | 03:26 PM
mschamberger's Avatar
mschamberger
Originally Posted by edensknight
Great photo, "GIB". Depending upon the brand, model, and, application, most "street" tires start life with 9/32 to 11/32 of tread depth, brand new. Now, if you look closely at this specific photo of yours, you will see a raised embossed Triangle Tire Emblem. In the tire industry, these triangular tire emblems are molded onto the outside shoulder edge of a tire, and, help to allow any consumer to locate the raised, rounded horizontal rubber bars called Tread Wear Indicators. These Tread Wear Indicators are located throuhout the surface of the tire, directly across from the triangular emblems, and, are generally at a height of 2/32 of tread depth. In general, you NEVER want to allow your tire to be worn so far down that you actually begin to wear down these Tread Wear Indicators.
Nicely stated EK.
Old Mar 24, 2006 | 03:30 PM
Dirty Howie's Avatar
Dirty Howie
Uhhhhh..That would be 1/16 right ??????
............. it has a "1" in it for first.......right???????
BUMMER......my NittoR2 tires only havef 5/32 to start with
DH
Old Mar 24, 2006 | 09:44 PM
az57chevy's Avatar
az57chevy
Well I guess I'll wait until it is 1/16 instead of replacing them at 10/160.
Thanks All I figured the bars were there somewhere now I know where to look
To Tread depth
Old Mar 24, 2006 | 11:20 PM
rws.1's Avatar
rws.1
Runcraps shold be changed if they are on your car....
no matter what the tread depth.
Old Mar 25, 2006 | 02:42 AM
Bill Dearborn's Avatar
Bill Dearborn
The original question was about the penny (I always heard it was a nickel but the distance may be the same on both coins). The distance from the edge of the coin to the head is 2/32 of an inch and is the same measurement as the wear bars on the tire. You put the coin in the deepest part of the tread to make the measurement. Although since the wear bars are on all tires there isn't much need to use a penny or a nickel anymore.
Bill
Old Mar 26, 2006 | 04:23 PM
edensknight
