Jacking puc question
Old Apr 4, 2006 | 06:56 PM
ricoZg's Avatar
ricoZg
Default Jacking puc question
When using jacking pucs, do you install them or do you only put them on when jacking the car?
I'm new to this so bare with me.
Mike G.
Old Apr 4, 2006 | 07:30 PM
dndrsn's Avatar
dndrsn
I'm new too but my take on it is, use 'em only when on a lift or jacking unless you have the BMW ones that snap into place. I could be wrong. Shoot me.
Old Apr 4, 2006 | 07:46 PM
rws.1's Avatar
rws.1
only put them in when you jack the car....
Old Apr 4, 2006 | 08:17 PM
ricoZg's Avatar
ricoZg
So then it would be alright to just get 2? Wouldn't you just need 4 if you plan to jack up the car on all 4 corners?
Mike G.
Old Apr 4, 2006 | 08:40 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Mike G.
Don't leave them in full time. ALways the chance you can bottom them out, especially if you're lowered. You'll need all four if you're taking her in for service and they lift it. They are a cheap safety measure so get the four. Alternatively, take a look at A&A's Frame Savers. IMHO this is the better way to go. More expensive yes but you no longer have to worry about
"pucs in - pucs out"
Old Apr 4, 2006 | 08:43 PM
ricoZg's Avatar
ricoZg
So the frame savers allow you to jack the car up?
Mike G.
Old Apr 4, 2006 | 08:51 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Mike G.
They should be removed after each use.
Old Apr 4, 2006 | 08:54 PM
ricoZg's Avatar
ricoZg
I just checked A&A's website. The frame savers are tiny wheels under the front bumper. Did you mean something else?
Mike G.
Old Apr 4, 2006 | 08:57 PM
c5BlackBeauty
Lifetime Member
Mike G.
Mike sorry for the confusion Go here:
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
Look at information for "Rocker Savers"
The Frame saves (The wheels) are a great functional enhancment as well, which will help save the front frame from scraping.
Old Apr 4, 2006 | 09:00 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I've got four of the BMW pucks in mine. I'm also lowered on stock bolts. I wanted pucks that would be in all the time. If I ever have a break down they are with the car- not in my garage.
Old Apr 4, 2006 | 09:05 PM
ricoZg's Avatar
ricoZg
Where could I get info on the BMW pucs?
Mike G.
Old Apr 4, 2006 | 09:10 PM
ricoZg's Avatar
ricoZg
Wouldn't I have to jack the car up first in order to install the frame rails?
Mike G.
Old Apr 4, 2006 | 10:01 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
Mike G.
www.bavauto.com jack support-E36 P/N51 71 1 960 752 I paid $6.95 each two years ago. I put a tiny dab of liquid nails on each one to make sure they didn't rattle. 22,000 miles and no problems. You can't see them unless you lean way over. Their sides are tapered so they won't catch on anything.
Old Apr 5, 2006 | 12:06 AM
Wisdom's Avatar
Wisdom
I use the BMW pucks too. Good idea about the liquid nails though. But I've never heard my pucks rattle when I've been in the car.
- Wisdom
Old Apr 5, 2006 | 10:51 AM
dndrsn's Avatar
dndrsn
Mike G.
You could drive it up on ramps.
Old Apr 5, 2006 | 11:21 AM
Mine are not put on the car unless I need to jack it up. They stay in one of the rear storage bins otherwise.
Old Apr 5, 2006 | 11:31 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
To Jacking puc question
Old Apr 5, 2006 | 11:33 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Here the low profile BMW pucks and the front frame saver wheels. The BMW pucks, are great I've had them on for 3 yrs and used a number of times with no issues.
Old Apr 5, 2006 | 12:18 PM
rwsr50's Avatar
rwsr50
From what I have seen of the "rock savers", don't they have built-in jacking/lifting pads that basically cover up the holes you would put pucks in?
They're nice, but what happens when you need to have the car towed. I understand that is where they hook up to winch the car up onto the rollback.
Old Apr 5, 2006 | 12:54 PM
ricoZg's Avatar
ricoZg
Hey Sponge Vette, are the frame savers still effective with that front lip?
Mike G.
