Is this Normal???
Old Jul 8, 2006 | 01:33 AM
daneaux's Avatar
daneaux
Default Is this Normal???
My belts, especially the AC belt squeals until it is warmed up, which for my A4 is around 10+ minutes. Once it is really warm, it gets better and almost completely stops the squeal.
The AC belt is so loud at start up, that I leave the AC off until warm, because people stare at it...they have to be thinking "whats up with that Vette".
Any ideas?
Old Jul 8, 2006 | 01:45 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
normal?? no.... how old is that belt?? have you checked the tensioner?? belts don't squeal for no reason....what have you tried??
Old Jul 8, 2006 | 01:56 AM
ja03c5's Avatar
ja03c5
Sounds like either the tensioner is loose or the belt is starting to go bad. Good luck!
Old Jul 8, 2006 | 10:30 AM
daneaux's Avatar
daneaux
I just got it back from the shop ( AC Repair) and that is when the squealin started.
They are good folks and had to order a part (tire sensor), so I will add this to the short list and get them to fix it. I will check the belt and tensioner now.
Thanks guys!
Old Jul 8, 2006 | 10:36 AM
DeeGee's Avatar
DeeGee
Before he "retired" from the Forum, E-T posted a good write up which I've copied below. It should explain the potential problems. I've seen some members lubricate the belt with various "potions" to try to stop the squeal.
"You have two belt systems on your car. One is the drive belt system, the other is the air conditioner belt system. The drive belt system consists of the serpentine belt, the power steering pump, alternator/gen, water pump, harmonic balancer, idler pulley, belt auto-tensioner pulley. The AC belt system consists of the compressor, harmonic balancer, idler pulley, belt auto-tensioner pulley.
First thing you need to do is isolate which system is squeaking. This can be done by releasing tension on the drive belt tensioner and removing the serpentine belt. This is the outboard belt of the two belt systems. If the squeak goes away, then it’s the belt or a component of the drive system.
If the squeak is still there, then it’s a component of the ac belt system.
To verify this, release the belt tension from the tensioner and remove the belt. If the squeak goes away, then it’s a component of the ac belt system.
A common problem is the belt tensioner on either system but verifying which system is at fault is the proper procedure.
You could replace both belts, but you may still have the squeak. If you want to find the culprit, isolate the system, then spray the belt of the offending system and see if the squeak goes away. Try to stay away from the idler and tensioner while spraying. I find that belt dressing may be good to identify a belt problem, but it is a temporary fix at best.
The real problem has been the tensioner and the idler. Both of these components have a sealed bearing which has been know to dry up or redirect the grease away from the bearing, thus causing the squeak.
If you find that a belt change does not correct the problem, then a change of both the idler and tensioner pulley is in order. If you just change the idler or the tensioner alone, it will cause the other component to go bad in a month or so. This has been the case with many members. There was a change made to the dusts seals to help correct this problem in newer C5's. Lots of tensioner and idler pulleys have been identified as a problem and it can effect either system. One is not more prevalent than the other. So find out which system is squeaking first, in the drive belt system. It could also be the bearing of the alternator, power steering pump, or water pump too, but these are less probable.
I hope this makes things a little clearer"
Courtesy E-T
To Is this Normal???
