How many have NOT had a column lock problem?
Old Aug 27, 2006 | 04:03 AM
  #81
dataporter's Avatar
dataporter
My 99 FRC with 50k + never had the recall (I think that is a good thing) and never had a problem. BUT two of my friends who have 99's have had problems, so last spring I put in a Thunder Racing CLB. Easy install, no problems, I'm glad it is in there.
Dave
Old Aug 27, 2006 | 05:32 AM
  #82
FiberglassFan's Avatar
FiberglassFan
Someone modified mine before I became its owner....The column does not lock with engine off-key removed. It remains turnable though firmly in Park, engine off, key removed.
If my car had not been previously modified, I would have installed a CLB kit. In recent months, GM has a final fix recall to remove the locking plate so it will never lock. I would never trust the original design to work forever. It is my belief that several of the one-car crashes we hear about are sudden column locking, not a good thing at speed!
Old Aug 28, 2006 | 02:33 AM
  #83
Windshear's Avatar
Windshear
I have only had the message once. I usually turn the key to acc. and pause till the fuel pump stops priming. This time I went staight to start and the car had sat for over a week. The battery was probabally a little low and with the fuel pump, starter and what ever else all taking power at the same time made me get the message,"Remove key for 10 sec".
Old Aug 28, 2006 | 04:50 AM
  #84
Oskee's Avatar
Oskee
Veteran: Marine Corps
I purchased my Y2K C5 new back in May of 2000 have not had the CL problem. GM has send me 5 recall notices in the mail to perform the recall....So far so good they will not touch my C5 vette has 15K miles.
I do have the CLB kit just incase it starts to act up ..
Old Aug 28, 2006 | 07:43 AM
  #85
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Have a '00 and never had a problem, but didn't want to risk it so I put a bypass in last Dec.
Old Aug 28, 2006 | 08:06 AM
  #86
blazeone's Avatar
blazeone
Two MN6 C5's. Put CLB's on them imediately after purchase. No problems.
Old Aug 28, 2006 | 10:07 AM
  #87
C5Jimmy's Avatar
C5Jimmy
I have a 2000 FRC No problems, also had both recalls done by dealer.
(Debating whether to install the CLB anyway, or can I after both recalls have been done?)
Old Aug 28, 2006 | 10:10 AM
  #88
HIRISC's Avatar
HIRISC
St. Jude Donor '06
Originally Posted by Grumpy
every A4 since 01 has not had the problem...
Old Aug 28, 2006 | 08:44 PM
  #89
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Can I install the CLB after the recalls, without undoing what has
already been done by the General?
Old Aug 28, 2006 | 09:10 PM
  #90
Vette04's Avatar
Vette04
2004 MN6. Recall 4006 done. No longer has column lock. No problems.
Old Aug 29, 2006 | 01:27 AM
  #91
z06inVB's Avatar
z06inVB
Before I bought my 01 Z 06 I wanted to drive a C5 so a buddy loaned me his 01 Coupe. First time I drove it I got the column lock and had to have it towed to the dealer. My Z is a two owner car with 70k miles. I talked to both owners before me and neither had an issue with it nor could I find any service record indicating a column lock issue or that any recall had been done. I am going to do the CLB on it anyway.
Old Aug 30, 2006 | 11:38 AM
  #92
JAZZ Z06's Avatar
JAZZ Z06
Default How many have NOT had a column lock problem?
I have a 2002 Z06 with 5K miles no problems. However I have two friends that have 2001 Z06s and both have had problems with lock columns, even after taking the cars to the dealers after the first occurrence. I biggest problem occurred with the friend that takes has car out of town. Once he had to leave his key in the car to avoid a problem. The latest was last week the column did not lock however the computer said it was and he was stranded (computer fuel pump cut off) and there were no dealers for seventy (70) miles. This was on a weekend and he had to trailer the car to the dealer Monday and fly back to work. The car is still there? Not an easy fix?
Old Aug 30, 2006 | 01:19 PM
  #93
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default clb YES
i had no trouble at 31k, but was hesitant to travel real distances, so i did the bypass anyway. dave
Old Aug 30, 2006 | 01:38 PM
  #94
Plentyfast's Avatar
Plentyfast
No problems
Old Aug 30, 2006 | 08:30 PM
  #95
fdxpilot's Avatar
fdxpilot
02 mn6 coupe. CLB installed after first recall, just in case. Never had a problem, before or after. 34K mi.
Old Aug 30, 2006 | 09:11 PM
  #96
davidwp97's Avatar
davidwp97
2001 MN6 Coupe - 50,000 miles - No problem - Did programming recall. No CLB, of course. Knock on wood!!
Old Aug 30, 2006 | 09:21 PM
  #97
Chaz 01's Avatar
Chaz 01
01, A4 Coupe 67,884 miles no problems
To How many have NOT had a column lock problem?
Old Aug 30, 2006 | 09:29 PM
  #98
vettephysician's Avatar
vettephysician
2003 C5 coupe, 14K mi., automatic, no problemo!
Old Aug 30, 2006 | 10:58 PM
  #99
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
2002 Z06, 34k no problem, but as a just in case i installed a clb last week, 2 days after my friends 99 locked up in his garage and he had to have it towed to a shop
Old Sep 2, 2006 | 02:51 PM
  #100
motordavid's Avatar
motordavid
'02 Vert, MN6...
Never a Col.Lock glitch of any kind...
had the local ChebbyStlr, (non-C5 tech),
do the latest version of the recall, a month ago.
No CLB, no bumps, no bruises, no bs, no probs in
4+ yrs and 25K miles...knocking on fookin wood.
