How many have NOT had a column lock problem?
It would have been better response/evaluation had you posted a poll for this purpose.
At a minimum, the poll should have included:
1. Ever Have CL? Y/N
2. If Yes to No. 1, do you have an A4?
3. If Yes to No. 1., do you have an MN6 or MN12?
4. If Yes to No. 1, do you have the aftermarket CLB (not OEM)?
5. If Yes to No. 1, do you have the OEM repair CLB?
6. Have you ever had CLB failure? Y/N
7. If Yes to No. 6 was it OEM CLB failure?
8. If Yes to No. 6 was it aftermarket CLB failure?
9. If yes to No. 6 was it another issue causing the failure? Y/N
10. If you have never had CL failure does you Vette have a CLB installed? Y/N
11. Is the CLB aftermarket? Y/N
12. Is the CLB OEM? Y/N
13. Have you had multiple CL failures? Y/N
14. If yes to No. 13, was itr due to the aftermarket CLB? Y/N
15. If yes to No. 13, was if due to failure of the OEM CLB? Y/N
16. If yes to No. 13, was it caused by another issue? Y/N
17. If no to No. 13, are you going to install a aftermarket CLB? Y/N
18. If no to No. 13, are you going to install a OEM CLB? Y/N
There may be other 'questions', but the above will allow a clearer picture of the CLB/CL matters (IMHO).
Good luck, cannot wait to participate.
My nieghbor had a 99 MN6 and no problems. He then got a 02 MN6 Z06and no problems.
My other neighbor had a 2000 A4 not problems and now has a 03 A4 and not problems.
And, it is early in the AM, if it was later in the day the questions would have been limited to two (2)
C
RVETTECORVETTE OWNER SINCE 1971 AT AGE 18
Celebrating 35 years of Corvette ownership
**I'm definitely in this for the long haul!**
But I truely believe you are on borrowed time. I hope being stranded never happens to anyone as it has occured to me and many others. $50 spent on insurance is worth every penny.
