AC Delco Batteries.
Old Aug 28, 2006 | 08:11 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Default AC Delco Batteries.
I know there has been quite a lot of discussion about the batteries in our cars. I just wanted to share a bit about a couple of recent events.
I killed the AC Delco battery in my 2000 coupe a couple of months ago. It was my own fault. I was working on the car and left the key on for entirely too long. I replaced it with a Die Hard (truck and suv with side and top posts).
Over the last couple of weeks I noticed my 1994 Sierra truck has been starting slower and slower. After sitting overnight last night, I was lucky to get it cranked today. I took it to Sears and had the battery tested. When a load was put on, it dropped like a rock. I had it replaced with a Die Hard Truck and Suv battery like I put in the Vette.
Now - The truck is a 1994 which I bought brand new. Without pawing through all my records to confirm, I have never replaced the battery. (When I replace batteries I almost always use Die Hards). So that makes the battery 12 years old with about 143,000 miles.
I don't guess they are all bad.
Just thought I would share.
Old Aug 28, 2006 | 10:07 PM
Dave68's Avatar
Dave68
I've heard of many 7 year-old AC Delco batteries, but never one that lasted that long! My OEM AC Delco AGM is still cranking away and it passed 5 years last June.
Old Aug 28, 2006 | 10:15 PM
BadAV's Avatar
BadAV
You're one of the lucky ones. I've never had a Delco battery go past 2-1/2 years. Motorcraft batteries, on the other hand, I've had really good luck with. I've never had one go less than 5 years.
I bought a Red Top for the Vette when the AGM died last fall (from the previous owner never driving the car - 1550 miles in 2-1/2 years). I hope I got a good one instead of one of the ones that dies. Actually, GM replaced the dead AGM under warranty but I put it in the Avalanche since Delco no longer has an AGM battery.
Old Aug 28, 2006 | 11:06 PM
ja03c5's Avatar
ja03c5
I have been driving GM since I've been driving...only had one problem with an AC Delco quitting before it should.
Old Aug 28, 2006 | 11:09 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I've had good luck with Delco - 5+ years in most cases.
Old Aug 28, 2006 | 11:49 PM
DeeGee's Avatar
DeeGee
Mine died on the Vert after only 8k miles. At least it just died
The AC Delco on the Camaro lasted 6 years but then leaked. I just do not trust them.
Old Aug 28, 2006 | 11:51 PM
silversport's Avatar
silversport
Delco Batteries exclusive since 1985...I always buy new after the "expiration date" has just passed...never one problem...now that must have done it!
Bill
Old Aug 29, 2006 | 12:46 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When I lived in Chicago - 6 or 7 years on a battery was no no big thing as long as you kept it filled with distilled water and kept the posts clean. And, as long as the rest of the car was well maintained and not placing an unneccessary drain on the battery - they lasted a long time.
When I moved to Arizona 15 years ago - batteries rarely go past two years, and I've had them all...Die Hard Heat Handler, Autozone's best 8 year battery with 3 years free replacement, OEM Delcos, Optimas and Exides.
With the exception of DeeGee - almost all you guys live in moderate climates, and I would expect no less. The worst possible climate is the desert - the high underhood heat, plus the high ambient summer temperatures kill batteries.
Old Aug 29, 2006 | 07:49 AM
Wow, that's a long time to get out of a battery. Sounds like you lucked out with that one.
Old Aug 29, 2006 | 09:14 AM
SpeedUp's Avatar
SpeedUp
was the 7 year ACDelco OEM equipment in the C5 ? I bought my C5 used, and that is what was in it. Its an 02, just wondering how old it is.
Old Aug 29, 2006 | 09:21 AM
Tom/99's Avatar
Tom/99
I got 10 years, 10 months out of the Delco battery in my 1985 Olsdmobile. I use nothing but Delco batteries in my cars.
To AC Delco Batteries.
