[Z06] Racing Helmets
http://www.araiamericas.com/Product_Tour.html
the GP-jet/F without the face lid on top
There are a lot of good helmets out there.
Bell, Ari, G-force, Sparko. with Bell be the most popular.
The trick is to get a SA 2005 rated helmet not a M for motocycle helmet.
Most car clubs will not allow Motorcycle helmts and need the SA or Special Application.
Dont even look at helmets that say " Exceeds Snell ratings" Most of thoe helmets are junk.
SA2005 helments have a nomex liner and a kevlar shell making them light weight too.
Get a full face helmet not an open helmet. Bugs and things fly into the side window and hit you chin all the time.
It you can try some helmets on to get the best fit.
Most popular tend to be the Bell M2 or M3 . I use the G-Force Pro Force 1. Fits my mellon better then Bell helmets.
I have a G-Force also and really like it. Fit is everything. You must get a Snell2005 rated helmet. You don't want an older (Snell2000) helmet, and definitely don't want a motorcycle helmet. What you will find as you look at them, they can get very expensive by adding a lot of bells and whistles that you probably don't need. Buy a good helmet -- your head is worth it. But you don't have to go for a bunch of graphics or other stuff that really adds nothing to safety. Try helmets until you find one that fits like a glove and doesn't pinch. And don't buy one that is too big. It must fit very snuggly and not shift when you shake your head hard from side to side.
So long as the helmet meets the following criteria:
1) It is Snell rated (has the Snell SA2005 sticker inside) as AU N EGL said
2) It is a full face helmet (again as AU N EGL said)
3) To emphasize .. THE MOST IMPORTANT PART .... so long as you are meeting #'s 1 and 2 is FIT.
Different helmet makers that meet SA2005 standards can still make helmets for different heads ... some of us have wide heads with not very tall faces, some of us have narrow heads with tall faces ... find a helmet that fits you PERFECTLY as this will be the critical factor in determining how well the helmet protects you. FIT is EVERYTHING once you know you're meeting conditions 1 and 2.
You should plan to spend at least $300 for a decent low end helmet. My Arai was $850, ouch! The only other advice I'll give is that you should get a snell 2005 helmet so its legal for the longest amount of time. You can still find deals on snell 2000 helmets which will still be legal/accepted for about 4-5 more years, but you have to decide which way to go there.
Bill
