Convertable Roll Bars
Old Oct 9, 2006 | 11:17 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Sully
I finally got off me **** and got the beast back to road worthy (non-vagrant) status after numerous therpy-inducing, poorly-serviced, wife-angering, wallet-cracking issues with the ride.
Hoping to get back out in the local scene a bit more now that, knock on wood, everything's running well
Old Oct 9, 2006 | 11:40 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Originally Posted by Mean Green
Sully
Very Cool! Glad to see you back!!!
Maybe next year I can come down and do a Sebring event with you.
Old Oct 11, 2006 | 01:19 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Now that sounds like a plan!
Old Oct 11, 2006 | 01:30 PM
GR8-LIFE's Avatar
GR8-LIFE
This is my only current shot of my roll bar. As you can see, it was designed for a petty bar which is the 5th point. The petty bar was recently authorized by a local drag strip But I never use the petty bar when I roadcourse
Old Oct 12, 2006 | 12:35 PM
azzhauler's Avatar
azzhauler
Is it possible to get a full bar that would pass safety inspection, but allow for the hoop to be disconnected for top up driving? Like the removable side bars.
Old Oct 12, 2006 | 12:51 PM
AU N EGL's Avatar
AU N EGL
if your talking about for HPDEs, track days. Maybe. There would need to be plates welded to the frame of your car so the roll bar could be BLOTED with big four 3/8"bolts to those plates on each of the four plates. Or some big ARP bolt of that nature.
For most HPDE or road track days, swing out door bars are highly discuaged do to saftey questions. Just remove them.
Rember guys dont put a roll bar in just to pass tech, it is for your safty.
Plus FIA padding on the roll bar and the 2" clearnce above the passangers helmets.
Old Oct 12, 2006 | 01:14 PM
Sully C5's Avatar
Sully C5
The way I read SCCA Solo I rules...
http://www.scca.com/_FileLibrary/Fil...solo_rules.pdf
Right now I am trying to find a way to comply with all the requirements and make it removable. It isn't easy!
