Battery for C5
Old Oct 12, 2006 | 06:30 AM
Delta3-2's Avatar
Delta3-2
Newcastle Batteries...made in Pennsylvania....not China or Mexico !
DG
Old Oct 12, 2006 | 06:32 AM
Delta3-2's Avatar
Delta3-2
Originally Posted by Dave68
This is but one of many, many posts about failed Optimas over the last couple of years:
http://forums.corvetteforum.com/show....php?t=1026859
Take a look at the Exide Orbital (AGM) or Marathon (non-AGM). Both feature much beefier contruction than the Optimas. Yes, they are also expensive, but both should last a good long time.
If you aren't screamish about lead acid batteries, then consider the 7-year AC Delco battery. It has a 50 month free replacement warranty - best in the industry. It is also highly rated, compared to most other batteries. Here's more info on cost-effective batteries:
Best for cold weather performance:
1. Everstart $60
2. AC Delco $90
3. NAPA $70
4. AC Delco (75 series) $90
5. Everstart, (75 series) $60 CR Best buy
"Batteries from EverStart, Kirkland, and NAPA are good values."
Best for warm weather performance:
1. NAPA $80 (series 65)
2. Duralast (65 series) $60 CR Best buy
3. AC Delco (65 series): $90
4. NAPA (75 series) $70
5. Nascar (75 series) $40 CR Best Buy
75 Series (the type used in Corvette C5s) batteries:
1. Nascar Select 75-84N (North) $80 Excellent reserve capacity
2. AC Delco Proffesional 75-7YR $90 Excellent CCA performance
3. EverStart MAX-75N (North) $60 Excellent reserve capacity, CR Best Buy
4. NAPA XLT N75-S (South) $70 CR Best Buy
5. Autocraft Silver 75-2 $55 Excellent reserve capacity
Notes: The best Diehard battery (WeatherHandler 30075 North) came in 9th place among the 75 series batteries. Its life test was below average, although its reserve capacity was excellent.
The best Interstate battery (Mega-Tron Plus MTP-75) came in 15th place. Its life test was below average.
I wouldn't hit a dog in the *** with an AC/Delco battery. If you recall these Delco OEM batteries are failing by the hundreds with the battery posts breaking off of them. My OEM Delco battery pooped the bed at 24,000 miles.
Newcastle Battery...that's the one for me. Made in Pennsylvania.
DG
Old Oct 12, 2006 | 07:05 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Optima---I wouldn't have one if you gave it to me for free....
Old Oct 12, 2006 | 09:54 AM
Dave68's Avatar
Dave68
DG
You may not know the history behind this, but some time after this was happening, it was discovered that GM was overtorqing the terminal post connections at the factory - certainly not a problem with the AC Delco battery design. AC Delco has a history of making reliable batteries long before many of you were born, and they will continue to do so for many years to come.
Old Oct 12, 2006 | 10:14 AM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Regular old walmart battery. always in stock
and ready to go. less problems than any of
them. just put a mat underneath in case of
leakage.
Old Oct 12, 2006 | 10:23 AM
Cole's Avatar
Cole
1. Everstart $60
2. AC Delco $90
3. NAPA $70
Trying to confuse us with facts?? Actually, I used Optimas for years - essentially since they came out and found they worked well in the Arizona climate. Then I needed a battery and the local Checker Parts only had Exide so I went with that. Ditto a few months later with the Corvette. Both have been performing well for close to three years and that is GOOD performance in Arizona. The big advantage to Exide and Optimas is the no leak upon failure becuase of the glass mat technology. So far neither of my Exides have failed or leaked so we continue to watch.
Old Oct 12, 2006 | 10:26 AM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Originally Posted by jrose7004
I'm happy with my Optima Red Top!
Old Oct 12, 2006 | 10:51 AM
DAN01's Avatar
DAN01
no problem with my optima red top either
Old Oct 12, 2006 | 12:06 PM
c5coast's Avatar
c5coast
So far I'm good with the factory battery. How long timewise before it craps out?
Old Oct 12, 2006 | 02:53 PM
cb5300's Avatar
cb5300
Well, all I can speak of is my own experience. I have 3 C5's and have had Red-Tops in all three of them. Biggest POS I've ever seen. It's true that I don't drive the vettes as much as I should, but that's just life. I also don't hook up battery tenders to them either. Red-Tops lasted 4 or 5 months, and would die deader than a door nail. The Advance auto battery I replaced them with seems to just last and last. Nothing has changed, the cars get driven the same as always with the only difference is that when you turn the key the engine starts right up and doesn't give you that Red-Top silence. As far as I'm concern red is over rated and a waste of money.
Old Oct 12, 2006 | 03:11 PM
Dave68's Avatar
Dave68
My OEM battery is almost 5 and a half years old. I expect it to last 6 years or more, but will probably replace it before its 6th birthday.
Old Oct 12, 2006 | 05:51 PM
stevzc5's Avatar
stevzc5
Me either
Old Oct 12, 2006 | 10:56 PM
  #33
gablkc5's Avatar
gablkc5
Cruising
Replaced my battery with an Optima Red Top last year and no problems at all.
Old Oct 13, 2006 | 07:59 AM
  #34
DeeGee's Avatar
DeeGee
Dave, sorry to disagree.
I like my Red Top but thats just me. The Exides get good press and I can see that its a good battery. But AC Delco
Just look at the failure rate in this poll. 54 failures against 86 good ones with 10 causing damage
http://forums.corvetteforum.com/show....php?t=1469503
Such a high failure rate for whatever reason is a serious issue particularly when a leak will trash the computer and wiring. Having had a "leaker" I'm not a fan
