Battery for C5
Old Oct 11, 2006 | 06:28 PM
micky z's Avatar
micky z
5th Gear
Default Battery for C5
What's the best battery to replace the stock one, in the C5?
Sounds like Optima battries are more trouble than they're worth?
Old Oct 11, 2006 | 06:35 PM
hotwheels57's Avatar
hotwheels57
...if you believe that you haven't read all of the replies to the previous OPTIMA discussions.
The % of complaints is far outweighed by those happy with them. Complaints (about any product) just get more attention.
I've been using OPTIMA batteries prior to their availability to the public. I have them in all of my current vehicles. I wouldn't use anything else until someone proves to me there's something better that won't leak and cause more damage.
Common sense would suggest to buy a fresh recent dated OPTIMA and maintain it with a float maintenance type charger during periods of non use.
Old Oct 11, 2006 | 06:45 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
......................... I wouldn't use anything else until someone proves to me there's something better that won't leak and cause more damage.
Old Oct 11, 2006 | 06:47 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
My Optima is serving me well.
Old Oct 11, 2006 | 06:49 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Seems like it's pretty much a crap shoot if you let it sit for several weeks on which battery to get. However, if you hook it up to a decent trickle charger (such as Battery Tender), you shouldn't have a problem.
Old Oct 11, 2006 | 06:54 PM
jbauch357's Avatar
jbauch357
I have an Exide Orbital and so far it has been great.
I was told that the terminals being seperated from the casing also solves pusling problems when you have high power demands from things like stereo amplifiers. Don't know if this is true, or if Optimas have this feature...
Old Oct 11, 2006 | 07:23 PM
DeeGee's Avatar
DeeGee
Take a look at this poll and form an opinion. The Optimas have a few problems but a lot could be car not battery related. Both mine are doing well. Exide performs well although its a small sample. Just don't get an AC Delco
http://forums.corvetteforum.com/show....php?t=1469503
Old Oct 11, 2006 | 07:34 PM
LoneStarFRC's Avatar
LoneStarFRC
Optima red top (34/78). Almost three years now and no worries.
Old Oct 11, 2006 | 07:57 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I am on my second Optima - first one lasted about 32 months, before it started to get weak. I took it back to Costco and got a brand new one for free. I also got one for the dd Blazer.
Old Oct 11, 2006 | 07:58 PM
C5naples's Avatar
C5naples
I like and use the Optima as well. I have had no problems and will use them in all our cars. I was a die hard delco fan prior.
Old Oct 11, 2006 | 08:14 PM
Blowtorch's Avatar
Blowtorch
I've had a Optima red top for 3 years. Never even think about..............That's my indication its a good battery
Old Oct 11, 2006 | 08:53 PM
Blue Lion's Avatar
Blue Lion
Optima red top here. Do your research--there are a couple of different models.
Old Oct 11, 2006 | 08:59 PM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Okay here as well
Old Oct 11, 2006 | 09:41 PM
ROJ#79's Avatar
ROJ#79
Optima
Old Oct 11, 2006 | 10:00 PM
My Optima Red Top has been in my car for five years - not once has it let me down. Would buy one again.
Old Oct 11, 2006 | 10:16 PM
Belkin1's Avatar
Belkin1
Les Schwab, Xtreme Power,$89, 84 month warrenty
Need I say more!
Old Oct 11, 2006 | 11:27 PM
Vettman 1's Avatar
Vettman 1
3 yrs.+ and no problems
To Battery for C5
Old Oct 11, 2006 | 11:41 PM
Dave68's Avatar
Dave68
This is but one of many, many posts about failed Optimas over the last couple of years:
http://forums.corvetteforum.com/show....php?t=1026859
Take a look at the Exide Orbital (AGM) or Marathon (non-AGM). Both feature much beefier contruction than the Optimas. Yes, they are also expensive, but both should last a good long time.
If you aren't screamish about lead acid batteries, then consider the 7-year AC Delco battery. It has a 50 month free replacement warranty - best in the industry. It is also highly rated, compared to most other batteries. Here's more info on cost-effective batteries:
Best for cold weather performance:
1. Everstart $60
2. AC Delco $90
3. NAPA $70
4. AC Delco (75 series) $90
5. Everstart, (75 series) $60 CR Best buy
"Batteries from EverStart, Kirkland, and NAPA are good values."
Best for warm weather performance:
1. NAPA $80 (series 65)
2. Duralast (65 series) $60 CR Best buy
3. AC Delco (65 series): $90
4. NAPA (75 series) $70
5. Nascar (75 series) $40 CR Best Buy
75 Series (the type used in Corvette C5s) batteries:
1. Nascar Select 75-84N (North) $80 Excellent reserve capacity
2. AC Delco Proffesional 75-7YR $90 Excellent CCA performance
3. EverStart MAX-75N (North) $60 Excellent reserve capacity, CR Best Buy
4. NAPA XLT N75-S (South) $70 CR Best Buy
5. Autocraft Silver 75-2 $55 Excellent reserve capacity
Notes: The best Diehard battery (WeatherHandler 30075 North) came in 9th place among the 75 series batteries. Its life test was below average, although its reserve capacity was excellent.
The best Interstate battery (Mega-Tron Plus MTP-75) came in 15th place. Its life test was below average.
Old Oct 11, 2006 | 11:42 PM
jrose7004's Avatar
jrose7004
I'm happy with my Optima Red Top!
Old Oct 11, 2006 | 11:51 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
3 month old Red Top working flawlessly!
Of course I don't have a high powered stereo system or a parasitic loss and have not hacked up the wiring on my Vette.
I think there is something more than meets the eye to all the proported pre-mature failures with the Optima's, but that's just my humble opinion.
Eat, sleep, and drive it like you stole it! Not necessarily in that order.
