new codes
Old Dec 24, 2006 | 12:14 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default new codes
after the header install, i've had a couple of codes thrown.... the first was because the air flow was changed by the new cats...ignored it...the second was code 1053 which has to do with the H02S (heated 02 sensor(s). can i ignore this one as well or will some serious problems develop? car runs fine... thanks, dave
Old Dec 24, 2006 | 02:31 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
ttt
Old Dec 24, 2006 | 09:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Who installed the headersand the CATs and are the wires and plugs properly insalled, are the O2 sensors installed in the correct sides and what year C5 and which headers???
BC
Old Dec 25, 2006 | 07:31 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
hey, bill. steve at ct corvette did the install and i'm p.m.ing now to check into it. the car is an '03, headers ar AR. i highly doubt that steve had reversed the o2 sensors. he's done plenty..
Old Dec 25, 2006 | 08:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep.
Steve contacted me. Looks like you may have a bad H2SO sensor. That would be common. Sometimes they don't take too good to being moved. Steve should be able to figure it out without a problem.
After he told me that he did the install, all of my questions were answered. He does good work and is very conscientious about his work.
Bill C
To new codes
