[Z06] major problem.. help!
Old Feb 15, 2007 | 10:21 PM
zwitherow's Avatar
zwitherow
Cruising
Default major problem.. help!
i hate that this is my first post, but perhaps you guys can help..
about a month ago i smacked the curb pretty hard in my car (02 z06). the front left wheel took most of the damage, and had to be pryed off of the rotor.
after getting it fixed, i drove it problem-free until the other day. i braked a little going about 120 mph, and instantly my car got sideways. it felt like the rearend just kicked about 2 feet to the left.
my first thought was either the front left rotor was warped, or the caliper was damaged.
but then, yesterday on my way home on the interstate, i went over a large bump at the end of a bridge (at about 60 mph) and the same thing happened.
so now i'm thinking it's a larger problem, but am clueless as to what it may be.
Old Feb 15, 2007 | 10:33 PM
63Corvette's Avatar
63Corvette
Unless you have a large life insurance policy paid up, please take your Z06 in to a reputable Chevy dealer and tell them what you have told us. Your wheel, suspension and/or other chassis parts are bent or broken.
Old Feb 15, 2007 | 10:36 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
To state the obvious something isn't fixed. Did you get a good alignment? Any tire problems? Brake sticking? ABS sensor?
Old Feb 16, 2007 | 12:13 AM
RonVette2's Avatar
RonVette2
Old Feb 16, 2007 | 12:59 AM
Gonzo's Avatar
Gonzo
Also, I'd stay away from 120 mph, you are just asking for trouble. Be safe, get it looked at by an expert with Vettes
Old Feb 16, 2007 | 01:05 AM
VetteTech81's Avatar
VetteTech81
Sounds like something is Loose! have it checked out imediately
-=Rick
Old Feb 16, 2007 | 10:12 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Old Feb 16, 2007 | 02:04 PM
zwitherow's Avatar
zwitherow
Cruising
the wheels were replaced after the curb incedent, and the car was 100% reliable, with no problems for over a month.
and another thing, the failure at 120 mph happened within 50 miles of an alignment. is there something the alignment shop could have done wrong or forgot to do that could have contributed to this?
Old Feb 16, 2007 | 03:34 PM
jbauch357's Avatar
jbauch357
if they accidentally left an adjuster loose it could be allowing caster, camber or toe to change drastically when under stress. this would account for the handling issues and the back end jumping out on ya...
I have seen a worn out trailing arm bushing make cars impossible to keep on the road at speed, the back end constantly fishtails and bounces side to side...
Old Feb 16, 2007 | 04:06 PM
zwitherow's Avatar
zwitherow
Cruising
thanks, this sounds exactly like the problem i'm having, and the fact that the car performed spot on for a month, and then failed directly after the alignment supports it as well.
im going to take it back to the alignment shop and see what happens.
Old Feb 16, 2007 | 06:35 PM
zwitherow's Avatar
zwitherow
Cruising
fixed.. the bastards at firestone didn't tighten everything down after they aligned it, took it to a dealership this time.
Old Feb 16, 2007 | 07:23 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Ouch
Old Feb 16, 2007 | 07:38 PM
jbauch357's Avatar
jbauch357
yep - that'll happen. Since you found a dealership that seems half-way confident you have truly found a diamond in the rough - better go buy a lotto ticket...
Old Feb 18, 2007 | 10:38 AM
mymaur's Avatar
mymaur
That fluttering sound you hear is your guardian angel hovering around. Slow down dude or your going to be in Corvette heaven.
Old Feb 18, 2007 | 10:55 AM
spdislife's Avatar
spdislife
To major problem.. help!
