Optima battery
Old Apr 8, 2007 | 01:03 AM
NOCKOUT67's Avatar
NOCKOUT67
Default Optima battery
HI , I recently purchased an Optima battery , its the red one , but its yellow inside .."LEMON". lol
I bought it new and it was only puttin out 10.5 v , I am returning it 4 a different one tomorrow .. MY question ? is it ok to put it on a 2amp trickle charge overnight .... thx
Old Apr 8, 2007 | 01:10 AM
DeeGee's Avatar
DeeGee
The Red Top has a 3 year return guarantee
I'd take it back if its been discharged and get a new one. Once these batteries are dischrged they can be tempramental. You may just be saving up a problem for the future.
I have a battery tender and I keep my Yellow Top hooked up when the car's not in use. Works just fine.
My Red Top worked great when I was using the Vert as a DD. It sat for 2 months not being used in transit to England and never recovered.
Old Apr 8, 2007 | 01:23 AM
NOCKOUT67's Avatar
NOCKOUT67
Default optima battery
Thanks 4 the info... but what is a battery tender.. ? I drive my 01 vert everyday to work , whoppin 3 mile drive round trip....
Old Apr 8, 2007 | 01:27 AM
bavaneld's Avatar
bavaneld
My experience with Optima has been this:
If you let a Red Optima drain totally its a goner. IE: Leave your radar detector on and don't drive your car for 2 weeks. There is no getting it back from that.
I bought a Yellow Optima a couple months ago and accidently left the detector on for a week or so again. Battery went dead but was able to charge it up again with no problems.
One more thing. Don't charge the Optima's with more than 10 amps.
Old Apr 8, 2007 | 01:28 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
A tender is a "float charger" Do a search. I also use a tender whenever the car is parked. Your electronics will be happier for it.
sooz's Avatar
sooz
Is there an echo in here?
Old Apr 8, 2007 | 01:32 AM
DeeGee's Avatar
DeeGee
Many of the Forum vendors sell them
Here's one from Jim at Southern Auto Parts as an example:
http://www.southerncarparts.com/corv...25a-p-190.html
Well worth the investment.
Old Apr 8, 2007 | 01:37 AM
NOCKOUT67's Avatar
NOCKOUT67
Default red top battery
Thankyou for the info , have a marvelous easter lol yeahhh
Old Apr 8, 2007 | 09:42 AM
EMDExpress's Avatar
EMDExpress
Total drain on my red top twice in the last six years. Still going strong.........
Old Apr 8, 2007 | 10:00 AM
Jims2001's Avatar
Jims2001
Get your money back and go to NAPA and get an Excide Orbital $122.95 plus tax.
Old Apr 8, 2007 | 10:04 AM
rogaljr's Avatar
rogaljr
Default Optima Battery
My suggestion is, do not use a "trickle" charger. They have a tendency to overcharge and damage a battery. Its best to use a "battery minder" which will monitor your battery and only charge at about 1amp until it comes up to float voltage. Vector Model VEC080 is a good unit. It is suppose to work with gel type batteries also (i.e. Optima), but when I use it on my Optima, it continuosly cycles from "charging to not charging" every 45 seconds. It works best on my Delco Professional 7 Year battery, which is an acid type. I only keep the Optima around for emergency situations....... "When I want to ride, I want to ride!!!!!"
Old Apr 8, 2007 | 01:13 PM
zTrek's Avatar
zTrek
I think we're talking semantics here. A Battery Tender (which is an actual brand name) is a "battery minder" type of device. It's multi-stage, microprocessor controlled charger that can be safely used with any type of automotive battery. I think some people refer to them as "trickle" charger" because they produce low amperage. Bottom line: don't just settle for "trickle charger but get one that has a microprocessor that actually monitors the battery's condition and charges accordingly (aka a "float" charger).
Old Apr 8, 2007 | 02:04 PM
vetred's Avatar
vetred
I just bought the yellow top at costco so,..Im not worried about a d**n thing,.......they don't even ask questions! just get another one!
To Optima battery
