Hurst short shifter
Old Apr 29, 2007 | 09:46 PM
jzemo's Avatar
jzemo
Have it and love it!!! Short and stiff, you can adjust the stiffness but I guess its all personal choice. Go for it!!
Old Apr 29, 2007 | 10:43 PM
vettegator005's Avatar
vettegator005
I have it and its amazing. The only problem i have with it is sometimes it doesnt want to go into reverse but being as i am not in reverse 99% of the time doesnt bother me that much.
Old Apr 29, 2007 | 11:39 PM
Sportsdude's Avatar
Sportsdude
No complaints
Old Apr 30, 2007 | 04:26 AM
Sorny's Avatar
Sorny
Shift into 3rd, then into R.
Sorny
Old Apr 30, 2007 | 04:27 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by hk940
i got the B&M but yea you need a short throw shifter. 100% best first mod you can do to the car to make it more drivable.
I had the B&M on my 1999 Z28! Night and day difference between the stock and short throw.
Old Apr 30, 2007 | 03:34 PM
steponc's Avatar
steponc
St. Jude Donor '14
Default Hurst short shifter
I used the stock shifter for about two months, then went to the Hurst. I then tried the C-6 shifter for about two months. I liked the position of the C-6 shifter and the **** so I put the Hurst back in after I heated the shaft, matched the bend of the C-6, drilled and tapped the shaft for the C-6 **** and went to the light springs adjusted very light. I am very happy with it now.
Old Oct 20, 2007 | 01:34 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
One of the main reasons I got the Hurst was because my factory C5 Z06 shifter some times had a hard time going into reverse. It is not the Hurst that is doing it, it is the transmission itself. Mine has 19K miles and was driven conservatively too, so its not a wear problem.
