SS Inserts falling off already?
Old May 8, 2007 | 11:28 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
Default SS Inserts falling off already?
I just put these on a few weeks ago, and already half my "R" has peeled away. I've driven the car daily, but have only washed it once by hand so I can't think of any reason for this happening. When I put them on, it was over the stated 70 deg. for a week and they didn't get wet for over a week.
Has anyone else had a problem, and if so how willing were they to offer a replacement? I'm planning on calling them tomorrow, and will be quite irritated if they tell me they're not doing anything. These were too expensive to fall off in a month. It's really too bad, cause they look great and I was impressed.
Old May 8, 2007 | 11:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've had mine on for about three months....I know you don't want to hear this, but I have to question the surface preparation.....did you follow the directions to the letter (no pun intended)? Did you use the adhesive promoter that came with the letters?
From what I've seen here - SS Inserts is a first class outfit, and I doubt that they will just blow you off - though I certainly cannot speak for them.
Good luck.
Old May 8, 2007 | 11:44 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
It is prep, but if you contact them they will send you a replacement letter.
Old May 8, 2007 | 11:53 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Hope you get it worked out.
Old May 9, 2007 | 12:10 AM
Illini82's Avatar
Illini82
St. Jude Donor '07
I cleaned the surface with alcohol prior to installing them.
It's funny you mention the adhesion promoter. When I got my letters, the promoter package had a hole in it and was dry. I called them (wish I would have got a name now) and they told me I didn't need it on a C5 and the C6's were the only ones who really needed it.... seems as though this wasn't the case. I'll see what I can do.
Old May 9, 2007 | 12:27 AM
jrose7004's Avatar
jrose7004
Like everyone said, prep is the key.
Old May 9, 2007 | 12:52 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old May 9, 2007 | 01:03 AM
BanditDude's Avatar
BanditDude
I noticed the same thing yesterday. I did everything according to the instructions, but my "R" was ready to fall off. I re-attached it with some 3M trim adhesive.
Old May 9, 2007 | 01:07 AM
DeeGee's Avatar
DeeGee
All I can say is I used the adhesive promoter which was provided and they're stuck firm. Dont think C5 and C6 paintwork is any different unless someone can enlighten me. I agree with Randy that prep is the key. A good clean out with a cotton bud should fix it.
Of interest, my only snag was the point of the R stuck out a little. It lost its sheen after a while with rubbing during detailing. I guess I just learned to live with it.
Old May 9, 2007 | 01:17 AM
WetteVette's Avatar
WetteVette
Default SS Inserts
My SS Inserts have been on about a month. No problems yet. Haven't "wet washed" my car yet. I Followed the prep instructions to a "T" (actually to a "E").
Hope they hold up well. They were just too damn expensive to fall off! Hope the manufacturer will help you out. Let us know.
Old May 9, 2007 | 04:41 AM
nonsuchpro's Avatar
nonsuchpro
This worked well for me on a warm and dry day:
1) Cleaned the area real good with soap and water....3 times. You can use denatured alcohol as well if you wish, I did not.
2) Dry throughly!
3) Heat up each letter's adhesive side with a hair dryer till you almost cant hold the letter in your hand.
4) While still hot, align and apply the letter (press firmly)
5) Allow some time to adhere before washing.
I wash my car just about every other day now.... they aren't coming off.... I'll be really surprised if they do.
Old May 9, 2007 | 05:39 AM
Y2K Corvette's Avatar
Y2K Corvette
Mine have been on for over a year now, many washings and many waxings, no problem with them lifting or coming off, because of past problems with this kind of thing on other cars, i really went over board on cleaning, wash, then i rubbed each letter with alcohol, then did each letter with alcohol on a Q-Tip and then followed the directions that came with my SS inserts, did same with the cyberdyne stickers on dash and steering wheel, so far no problems, good luck
Old May 9, 2007 | 06:49 AM
Everything I have heard about SS Inserts is they will take care of you. Give them a call and explain the situation.
Old May 9, 2007 | 08:18 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I cleaned mine with Dawn, then with alcohol, then I put them on and held each one in place for about a minute. That was 3 years ago...
Old May 9, 2007 | 08:21 AM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
Three sets of SS Inserts on three different cars in four years...no problems.
Old May 9, 2007 | 08:38 AM
steve8's Avatar
steve8
I hate to say, but I agree with the others about the prep.
Talk to them and I am sure they will help you out.
I got mine from COH and two = years now and no problem.
They even sent me a new R as I didn't like the way it came to a point.
Old May 9, 2007 | 09:22 AM
BT-01-vette's Avatar
BT-01-vette
5yrs 55k miles (not daily driver but a garage queen) no problems
To SS Inserts falling off already?
Old May 9, 2007 | 09:37 AM
krm_wi_C5's Avatar
krm_wi_C5
I also bought the SS Inserts. I spoke to Barry over the phone to get some "tips" on installing the letters prior to buying them. He recommended cleaning each application area with laquer thinner, using a q-tip, then using the adhesive promoter that came with the letters. I did that, the installation went well, although I did notice that the "R" does not fit the same as all the other letters. It is not coming loose yet. I did ask Barry if the warranty would cover a letter that falls off, he says it does providing the installation is done as instructed. A couple of other things, he said do not use alcohol or hair dryers, which surprised me. He said that hair dryers should be used to remove the letters.
Old May 9, 2007 | 10:33 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
plus when you hear the letters falling off it is always the R
Old May 9, 2007 | 11:52 AM
rws.1's Avatar
rws.1
I used 3M wax and adhesive remover to prep the indents before I applied my letters.
1+ year and counting....
