Verts With Rollbars
Old Jun 26, 2007 | 02:56 AM
Brad@RevXtremeAutoSports's Avatar
Default Verts With Rollbars
May I see your pics please and descriptions/specs? Also, are you happy with it?
TIA
Brad
Old Jun 26, 2007 | 10:21 PM
Bump
Old Jun 26, 2007 | 10:27 PM
jon c's Avatar
jon c
Old Jun 26, 2007 | 10:35 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
A little hard to see here. Need some better shots. These are from RK Sport. Good price, great service. Quality is good. They are a little smaller than I'd hoped for, I think I'd rather have 2" but they are hard to find. A lot harder to get a clean install (carpet cuts) than I expected.
I really like the look though.
Old Jun 27, 2007 | 02:24 AM
OMG its Jason's Avatar
OMG its Jason
Are you talking about hoops or the roll cage?
I would be very interested in seeing a vert with a roll cage myself.
Old Jun 27, 2007 | 02:46 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Cage kind of defeats the reason for having a vert. I have only seen one was done by ECS. A real roll bar is all is needed unless you are really out there racing door to door. Those dress up hoops are not good for anything but looks.
Old Jun 27, 2007 | 05:44 AM
Vettman 1's Avatar
Vettman 1
These are from WCC
the trim rings are courtesy Lowe's plumbing dept.
Old Jun 27, 2007 | 08:46 AM
13.49 is the cut off point at the drap strip. I'm under that. Wanted to see id anyone had the roll bar.
TIA
Brad
Old Jun 27, 2007 | 09:00 AM
OMG its Jason
Do those qualify as "roll bars"?
I need to know this as well as I am obviously running better than 13.49 with my current setup.
Old Jun 27, 2007 | 09:05 AM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Originally Posted by Vettman 1
These are from WCC
I like these. I'm hoping to do them over the winter months when I do the Audio..
Old Jun 27, 2007 | 09:07 AM
AU N EGL's Avatar
AU N EGL
NO. Check the NHRA web site.
A roll bar needs to be above your head. One continious hoop from side to side, One diagonal tube with in the main hoop. a minium of two down tubes from the main hoop. all four contactets welded to the frame of your car.
Figure a min of 1 7/8 OD tubing.
Plus it must be at least 2" above the top of your helmet.
Old Jun 27, 2007 | 09:12 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
here are a few pics for you guys. A roll bar is either a 5 or 6 point and the car is legal for 10.0 et. A roll cage is where the bars go through the dash. the first 2 pics are a roll bar and the second 2 are a full cage..
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jun 27, 2007 | 09:23 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Old Jun 27, 2007 | 09:25 AM
OMG its Jason
Thanks chris.
I can probably live with a roll bar on a convertible, but I cant justify a cage. Just defeats the purpose I guess.. Do you sell rollbars?
Old Jun 27, 2007 | 09:36 AM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
These are from WCC
Your hoops really look nice! How much were they and did that include installation?
I have been considering hoops in my '02 M.Y. roadster and have talked to Steve (270) 842-4409 at MMRC up near B.G., Ky. He sells them for $500.00 or $600.00 installed. I was planning to have him install them while I was in B.G. the week before last but I was too busy to get with him.
For those of you who have hoops, do they obstruct your ability to recline your passenger seat like when on a trip and trying to snooze? I don't want to have to sit up straight all the time if I'm trying to nap.
Sanford
Old Jun 27, 2007 | 10:20 AM
Cruise-In V Veteran
It depends on who is doing the install. Its quite complex and really not recommeded for a home install.. Feel free to give me a call and I will go over some options..
Old Jun 27, 2007 | 10:23 AM
XLR8BYU's Avatar
XLR8BYU
I have a custom roll bar from MTI racing in Atlanta. It's attached @ 4pts. behind the seats and 2 bars extend back into the begining of the trunk area. It has allen bolts to attach to the extenders that enables me to push it forward to raise and lower the top. I will get some pics for you...
Certified for track days @ Road Atlanta and to 150 in Land Speed Racing. Haven't been to the drag strip yet....
To Verts With Rollbars
Old Jun 27, 2007 | 04:35 PM
ICaughtVetteFever
I figured as much, that is why I said all you need is a bar, not a full cage(unless you are <9.99) like someone mentioned.
Old Jun 27, 2007 | 05:10 PM
Sully C5's Avatar
Sully C5
By Road Atlanta I assume you mean Panoz Track Days. If so, Panoz requirements are significantly less than what you need for the dragstrip. Most of the MTI rollbars I have seen at RA would not pass NHRA or SCCA. Last time at RA there was a Viper there with an MTI rollbar and the driver's helmet was above the bar.
I run a Wolfe 4-point, but it does not pass NHRA.
http://www.wolferacecraft.com/install/c5/c5conv.aspx
Old Jun 27, 2007 | 05:14 PM
chaase's Avatar
chaase
St. Jude Donor '12
Most governing bodies requrie a 5pt.
