Garage Door Spring Broke !!
It's one of those coil up, I think they call them Torsional springs.
I wanted to take the car out yesterday cause it was nice but I couldn't get the stinking door open. ( They are pretty heavy )
I tried lifting it, but no way.
I looked into changing it myself but most say do not do it, you will kill yourself, so someone is supposed to come out today to replace it. (both springs actually) Between 10:00 Am and 2:00 Pm.
So I'll be OK, I'll make it thru my withdrawl of not being able to drive my Vett .... hope they come early.
Glad all's well except for the inconvenience of not being able to open the door.
) All the more reason to have 9 foot doors and not 16's!! Easier to lift when the spring breaks...!!
One thing I do know is the last time I replaced one of my springs, (I have a torque tube spring in each of my doors, not a torsion) That if you coat the spring with grease, it is supposed to help make it last longer and work better. I know in my case, it definately works beter and is not wound as tight to do the same work. They also say to buy galvanized springs when you replace them. Again, it works better and longer life is expected... I've heard 25% improvment...
For what it's worth anyway...
PS, the torque tube style spring is only available as a total replacement for torsion springs. It's an enclosed spring in a steel tube and is VERY user friendly!! You use a drill to wind a small wall mounted right angle winder.. very neat and simple!!
I've also now seen a torsion spring winder that is VERY much the same. EASY, simple and safe!
Menards - but maybe only fits the door sold there???I do NOT recommend thay anyone try winding or adjusting a normal torsion spring.. It IS very dangerous and you can get hurt VERY easily!!
Hope you're back on the road soon.
I guess I find this subject amusing since I've done it myself several times now. If you work on your own car, you can replace garage door springs and live to tell about it.
Rick
I was told the same thing (by people wanting to charge me to replace it, or by people that have been told that and never done it themselves). I changed them myself. It's not a big deal once you do a little reading on how to properly/safely do it. It's the same as saying changing a tire on your car can kill you (and many people do die every year doing it) if you put your head under the car and knock it off the jack. Yes it's scary knowing the spring can break at any time you are winding it, but it won't hurt you if it does go (it will scare the crap out of you though).
I've heard that too and think it's BS (for an "ordinary" torsion spring set-up). Take a look at your springs. They slip over the large shaft that runs from side to side. If the spring breaks, it is still contained on the shaft; a lot of noise and rattling around, but not really much danger.
Rick
Its the spring on each end of the door that goes flying, unless you have a restraing cable running through the middle of them . Or I think the new ones have a built in restrainer now.
Also, forum members hosenfeferdave and Myown69 have reported flying debris from broken garage door springs here in the past as well.
These may have been older springs with no safety measures installed to prevent shrapnel but they show it can occur.
Bill
A neighbor of mine had one break and that thing beat the heck out of his car and ended up stuck in a wall clear accross the garage.
it sounded like a bomb going off. these are definately not something you should fix by yourself. those springs have lots of force packed in them when in place.
My bad.... I didn't realize he was talking about that kind of door and spring. Mine are vertical with the door hinges and they are easy to replace when they break. Well, thanks for the correction.
I tied a rope around the center reinforcing section of the bottom of the door and put the rope over my shoulder to lift with, combined with the garage door motor and another person also pushing up on the door. We got it open, but man was it heavy without the spring. We got the vehicle out of the garage and awaited the repair man since he could not come until the next afternoon.
I hired an independent garage door repair man to replace the spring. The grand total was only $125.
You can get regular steel springs or stainless steel springs. They have a rating of so many duty cycles and then they will break. I used to oil the springs and wire cables down the sides of the doors with WD-40 annually, but it did not seem to make the springs last any longer.
