IPOD2 Car
Old Oct 7, 2009 | 04:01 PM
  #481
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by Jade Euphoria
If you can use it with the iPhone, it plugs into the headphone jack right? Sooooo, does that mean you can talk on the phone and hear it thru your speakers? My bf has his rock crawler wired to plug into his iPhone, and when someone calls, you can hear them thru the speakers, and they can hear you from the phone as if it was on speakerphone.
Anyone using their phone with the ipod2car hookup like this?
Jupiter Jack does that. Target Sells them.
http://www.asseenontvguys.com/index....ROD&ProdID=652
Old Oct 7, 2009 | 06:19 PM
  #482
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I'm glad you responded. I don't know nuthin bout no Jupiter Jack!
Old Jan 19, 2010 | 04:00 AM
  #483
B-rent's Avatar
B-rent
Bringing it back from the dead
Is the kit long enough to plug into the te cd changer in the back and go all the way and run threw the console and hook up to the Pro-clips mount? Or is the wire just long enough to reach the center console?
Thanks!
Old Jan 19, 2010 | 02:21 PM
  #484
ScottJ97's Avatar
ScottJ97
It should be plenty long for that. I have mine going from the CD changer in the back, over the right rear wheel well, behind the passenger seat, and into the console where it connects to the spec.dock in the cupholder. And there is a foot or more (I forget exactly) of wire length remaining.
Old Jan 19, 2010 | 02:28 PM
  #485
HowlinC5's Avatar
HowlinC5
So, does the CD changer still work with this setup?
Old Jan 19, 2010 | 02:32 PM
  #486
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
So... there's no way to just plug into the back of the factory head unit and hit the "AUX" button?
Just curious since I just got an i-pod and have a cable for using it in my 09 Sierra, but the Z06 is way different.
Old Jan 19, 2010 | 02:40 PM
  #487
ScottJ97's Avatar
ScottJ97
No, the ipod2Car plugs in to the end of the cable that originally went to the CD changer.
I believe there is also a way to plug in to the back of the head unit, but I'm not sure about that.
Old Jan 19, 2010 | 03:00 PM
  #488
Cozmo's Avatar
Cozmo
You can do that if you do not have a 6 disc changer in the trunk. Togue wrote up a very nice description of the installation procedure with pics.
Old Jan 19, 2010 | 03:16 PM
  #489
AverageVetteNut
Thanks! I do NOT have the changer, so I'll have to look into that.
