Not the normal tire question
Old Aug 10, 2007 | 06:24 PM
peachtreeplaya's C5's Avatar
peachtreeplaya's C5
Default Not the normal tire question
I went to get a pair of new tires for my C5 and then next payday I will get another pair. Well I'm at the shop and the guy comes out to tell me that since I want the new tires on the front he has to read me a warning from the tire manufactures. Basically he read a warning that says the manufacturer recommends the newest(tire with most tread) tires go on the rear of the car. New to me anyone heard of this? If so why? I thought you stood less chance of hydroplaning with new front tires.
Old Aug 10, 2007 | 06:29 PM
ScottJ97's Avatar
ScottJ97
Probably because it's safer to lose traction on the front wheels first (understeer) than on the rear wheels (oversteer). For inexperienced drivers especially.
Old Aug 10, 2007 | 06:30 PM
The Wanderer's Avatar
The Wanderer
When I sold tires back in the 70's it was just the opposite. You wanted to have the best tires on the front because they are the steering tires. Always made sense to me.
Old Aug 10, 2007 | 06:33 PM
AtiLLa's Avatar
AtiLLa
the one and only time that i ever hydroplaned and lost control was in a nissan xterra suv and it was the rear tires that broke loose from the road first.......not sure if that has anything to do with the warning or not though.....
atilla...
Old Aug 10, 2007 | 06:35 PM
moserbe's Avatar
moserbe
He was probably trying to get you to buy all 4.
Old Aug 10, 2007 | 06:36 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Nanny Lawyers
Sounds to me like everyone is so paranoid over lawsuits. Seems to me if you want new tires on the front, you should be able to get them. As far as hyrdoplaning, your front set of tires will be hitting the water first, of course and the rear tires are riding in the area first cleared by the front tires. With that being said, if conditions are such that you are in that much water, slow down, and you should have good tires at all four corners. I regret that our society has regressed to the point of some tire guy having to tell "YOU" about what he and his company "think" is best and safest for "YOU"?
Old Aug 10, 2007 | 06:37 PM
lil vette's Avatar
lil vette
fiddly dee
one week, you could put them in the trunk, big deal.
what's a week, like wow, we may have a blizzard in august.
Old Aug 10, 2007 | 10:48 PM
wamara's Avatar
wamara
Cruise-In II Veteran
The tire industry's current CW is that a pair of new tires should go in the back. Since they regard that as safer, it's not surprising that you were given the warning lecture, given our litigious society.
Old Aug 10, 2007 | 10:56 PM
C5naples's Avatar
C5naples
I never heard of that. If you are concerned then buy all four tires on the next payday
Old Aug 10, 2007 | 11:09 PM
Ettev01's Avatar
Ettev01
Is that why those racers put "slicks" on the front of their cars? He's an idiot. I've never heard such crap!
Old Aug 10, 2007 | 11:25 PM
WildTurkey's Avatar
WildTurkey
Why not just wait 2 paydays and get the whole job done at one time (i.e. problem solved...and probably lower labor $$$)?
Old Aug 10, 2007 | 11:40 PM
Flat Broke's Avatar
Flat Broke
When I was young we always put the new tires on front in case of a blowout. But the man was covering his a$$ and he is correct. If you are driving and hit the brakes and the front wheels lock up and the back ones don't the car will remain headlights first. If you are driving and lock the rear wheels up and not the front, the taillights will lead the way as the car will swap ends. You can prove this with a toy car. Tape the front wheels so they won't turn and give it a push across the floor and it will go straight. Now tape only the rear wheels and do it again and watch it swap ends and go backwards. The tires on the axle that lock will lead the way, always. His reasons had nothing to do with hydroplaning. If you hydroplan new tractor tires all the way around won't help.
Old Aug 11, 2007 | 01:24 AM
Dave68's Avatar
Dave68
The bottom line is that you have more control of the car in the event of a blowout if the blowout occurs to a front tire. But because our cars have different front and rear tires, there will be times when you will need new front tires, only. It would be crazy to replace half-worn rear tires, just because the fronts will be newer.
Get the front tires now and replace the rears when they are worn out.
Old Aug 11, 2007 | 03:02 AM
ptindall's Avatar
ptindall
The car has 4 wheel ABS. The car will compensate for different traction levels at different wheels and will not lock any of them no matter what tires you have. They are worried about handling. Oversteer caused by good front tires and bald back tires. And oversteer is dangerous to stupid drivers. In our society now, that's what everyone is assumed to be. Stupid. I have been told this in the past by Discount Tire. They have to say it to avoid lawsuits. Tell them just do it. They will. Then forget about it, you will be fine.
Old Aug 11, 2007 | 03:14 AM
DeeGee's Avatar
DeeGee
I think that one rasied the flag. He cant say that without being specific to your car.
It would depend on front or rear wheel drive and tread depth on the remaining tires.
On a rear wheel drive Vette you might find a handling difference for a while.
One thing I wouldn't do is mix runflats and non runflats.
To Not the normal tire question
