Security light caper- solved!
Old Aug 24, 2007 | 10:15 PM
Frozenfire's Avatar
Frozenfire
Default Security light caper- solved!
Some months back I reported on having intermittent problems with the car starting. Even trying both keys, sometimes the security system "thought" that the car was being stolen. (Sometimes at very inopportune times and places!) At first, the dealer said that the computer showed no problems with the security system. When I told them that the SECURITY remains on while driving, they took a closer look. Turns out that it wasn't the chip on the keys, it was a worn out cylinder in the lock assembly. After 7 years of inserting and removing the key, the contacts in the lock tend to wear. Fortunately, the work was covered under my extended warranty. Problem corrected.
So, if your anti-theft system acts funky and it's not the chip in the key, it could be the ignition switch.
Old Aug 25, 2007 | 01:56 AM
Dave68's Avatar
Dave68
Thanks for the tip, I will have to remember that, now that my baby is over 6 years old!
Old Aug 25, 2007 | 02:23 AM
RoccoC5's Avatar
RoccoC5
Yeah, good info. Hopefully I won't have to put it to use, but at least I know of a potential problem to look out for!
Old Aug 25, 2007 | 02:29 AM
DeeGee's Avatar
DeeGee
Good tip thanks
Old Aug 25, 2007 | 09:22 AM
OzzyC4's Avatar
OzzyC4
The ignition switch isn't worn out, the lock cylinder is worn out.
Dont go asking the parts house for an ignition switcch unless you like going through hell to change it out and then find your problem is not cured!
Old Aug 25, 2007 | 10:48 AM
RedRider98's Avatar
RedRider98
Totally agree. I just replaced my lock cylinder yesterday due to a security VATS issue (code B2723). Problem solved. But, the issue is with the ignition lock cylinder NOT the ignition switch!
Old Aug 25, 2007 | 10:55 AM
csexton's Avatar
csexton
Good info
Chuck
Old Aug 25, 2007 | 11:34 AM
Frozenfire's Avatar
Frozenfire
That's what I meant- the cylinder, not the switch. Thanks for the clarification!
Old Aug 25, 2007 | 01:53 PM
Nice to know - thanks for the info.
Old Aug 25, 2007 | 04:23 PM
LoneStarFRC's Avatar
LoneStarFRC
Good info Frozenfire.
BTW, keeping the large bundle keys and other assorted stuff, off of the key ring helps extend the longevity of the lock cylinder. I have a "quick release" on my key-ring that only has the ignition key on it so when driving, only my key (and small ring) are hanging off the switch, while the rest of my keys, fob, etc are in my pocket.
Old Aug 25, 2007 | 06:51 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You have all that in your pocket - and here I thought you were just happy to see me!
Old Aug 25, 2007 | 07:10 PM
LoneStarFRC
Aha! A fan of Mae West I see.
Old Aug 25, 2007 | 07:25 PM
6pac's Avatar
6pac
My problem is that after hard turns the security light just comes on during driving and turns off when I turn the ignition off...only to come back on the next time I am out for a drive?
Old Mar 30, 2008 | 09:14 PM
smr4real's Avatar
smr4real
Default Likewie
I have the same situation occuring. Do you have (ohave received) a solution?
To Security light caper- solved!
