i just got new rotors and pads on, and my pass front pad seems to be lightly touching the rotor at all time, and it's making a really annoying noise. i tried bedding them, but i've never done it before and i dont know how long i have to do it for. does that even sound like a pad problem, and will i just need to continue bedding them for a while longer?
From what I know, disc brake pads always "touch" the rotor. That is one of the reasons disc brakes work so well, very little mechanical movement to engage the brakes. There are check valves in the system that always sustain a certain pressure so immediate braking is always available.
yeah but then it should be all of them doing it, not just one. i'm worried the pad is in ****-eyed or something cause it's not going away after breaking and i've done it many times, even yesterday.
well that site was really helpful, well it probably would have been, but it didn't work. i tried it but no banana. so i'm just going to take it to a brake shop tom. thanks though!
If you're going to a brake shop have them check for lateral run out on the rotor. make sure it's within tolerance. Recognized issue with C5s. There's a TSB out on it. Mostly causes pulsating, but should check anyhow while its in the shop.
After install drive and be gentle on brakes (as little as possible and no hard breaking unitl you do the 60-30 series) find road where you can do 60-30 rapid breaking 5-8 times, afterwards drive for another 10 minutes to let brakes cool and you are good to go. No problems on any of my vehicles.
yeah, i think the problem was initially, was when i was leaving the shop there was a lot of stop and go traffic and i had to slam on them from people cutting me off and what not. so...i'm taking it tomorrow. we'll see
Ok guys, the Idea of being gentle on your brakes was written by lawyers.
Go find a nice quite, low to no traffic straight road. Day light only.
Do 3 to 5 easy 40 to 10 mph stops. ( This puts heat into the rotors and pads) Do them one right after another
next do 3 to 5 HARD 40 to 5 mphs. Hard means stomp on that brake peddle to activate ABS. Almost like doing a motorcycle stoppie, put the nose on the ground.
Next do 3 to 5 HARD 80 to 5 mph stops. again STOMP on that brake peddle.
Then drive aroud for 30 to 50 min too cool the brakes down and put your car away and dont drive it for 24 hours to finish the brake cooling period
No ***** foot stopping. HEAT comes from friction, Heat is used to bed in brake pads to rotors. Bedding of each is the transfer of brake pad material to the rotor.
Hard braking also teachs straight line emergancy braking.
You only need to do 20 consecutive stops from 30 mph. After the pads are installed and your ready to roll, start off go to 30 and apply solid firm brake to a stop, take off again to 30 and bring it to another stop, repeat this until you have done 20 stops. Bring the vehicle to a stop and let the brakes cool down and your good to go.
By the time you have reached about the 18th stop, you will start to smell the pad material heating up and depending on the type of pad installed you may start to experience fading through to the 20th stop. This is normal and expected, also a good time to learn what brake pad fade feels like.
Bedding brake pads is also a good way to find out that you probably need to flush your brake fluid too if you haven't already done so.
Old fluid + heat = pedal to the floor. Lots of fade.
well it was stopping great, and it's weird cause it's only this one pad? i finally dropped it off so i'll know in an hour and ask him about the fluid. thanks
ok well i got it back yesterday and it is fixed...finally! anyways he ordered ceramic coated pads, supposedly acdelco's best pads. they're on now and haven't made any noise or anything. the old pads were pitted real bad. MTI refunded my money. i think the rotors produced more heat than the OEM pads could handle.
When I was checking my front wheels the other day for a bad bearing I took a real good look at my pads and rotors. To my surprise, I found that there is very little (read NONE) tolerance between where the pad meets the braking surface of the rotors and the rotor "hats". I was shocked beyond belief to see that the edges of the pads actually ride ride up next to the hats, if not touch them slightly. What a lousy design!
With that said, could it be that your new pads actually sit in a way that the edges of the pads slightly exceed the braking surface of the rotors and slightly overlap onto the rotor hats, which are slightly raised compared to the braking surface? If so, the pads' edges are being chafed by the rotor hats, which might explain what you are experiencing - more than normal drag, and even some noise. If that's what's happening, provided the pads are just over the edge onto the rotor hats, I would expect that over a short period of time the edges of the pads will wear off enough that they would no longer "drag" on the hats or make noise.
