clutch switch?
Old Sep 5, 2007 | 12:18 PM
bhard's Avatar
bhard
Default clutch switch?
hey i checked the battery, it was fine car still wont turnover. how hard is it and how do i check the the clutch interlock switch.
thanks
Old Sep 5, 2007 | 01:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Not difficult at all. Just unplug the switch, Install a paper clip in the connector and that will essentially BY PASS that switch. You can also see if it is working by depressing and releasing the clutch while at the same time listening for the Theft Deterrent Relay (TDR) in the passengers foot well to click when the switch is pressed and released. The TDR can also be defective. It on the passengers side in the foot well on the fire wall above the BCM...
Are you SURE your battery terminals are clean and tight!!!???!!! They cause this problem a LOT> Are you sure the battery is also good??
BC
