trunk liner help
Old Nov 2, 2007 | 12:53 PM
khblair's Avatar
khblair
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
Default trunk liner help
i have a black embroidered convertible trunk liner - it wont stay attached to the trunk lid!! the glue on the trunk side of the velcro strips ... keeps coming off. anyone have any advice? i was thinking Liquid Nails..
Thanks!
Old Nov 2, 2007 | 01:21 PM
DeeGee's Avatar
DeeGee
I had the same problem. I tried various glues and different strength velcro. Nothing worked.
I eventually drilled 4 small holes and used push pins. its been fixed solid for about 3 years now.
Take a look at my post in the DIY thread in C5 Tech post #14
http://forums.corvetteforum.com/show....php?t=1817090
Old Nov 2, 2007 | 01:23 PM
hotwheels57's Avatar
hotwheels57
The hood insulator retainers as suggested are probably the best idea.
You can buy wider industrial strength VELCRO from HOME DEPOT and other sources. I use it to mount my BATTERY TENDER to one column of my lift. It's solid as a rock in AZ summer heat in my shop/garage. It's very difficult to remove w/o a heat gun and lots of patience. It comes in a roll of 4 ft long and 2" wide as I recall.
Old Nov 2, 2007 | 01:24 PM
TOOGECKO's Avatar
TOOGECKO
3M makes some very heavy velcro type strips. I have a prototype liner that someone made me and it is heavier than any I have seen or tried; it has not come off once in the three years I have had it...
I believe this stuff was white hook and loop not like the heavy-duty stuff you see at Home Depot or Lowes...
Do an online search and see what comes up
Old Nov 2, 2007 | 01:34 PM
DeeGee's Avatar
DeeGee
I even tried 1" industrial strength velcro. i think my problem was I used peg board to build the liner so it was heavy. Got fed up coming back and finding the liner on the floor of the trunk
I gave in and drilled the holes. No more problems.
Old Nov 2, 2007 | 05:09 PM
LTCHAPPA's Avatar
LTCHAPPA
Take off those velcro pieces with the sponge on the left and right sides.Get some 3M industrial double sided tape,it has a red liner.Get some strips of wood about 8 inches long three quarters inchs thick by about one inch wide Put the tape on both sides of the wood,Now stick the wood to the liner and then to the trunk lid. LT
Old Nov 2, 2007 | 09:03 PM
boblud's Avatar
boblud
A couple of drops of Gorilla glue on each strip works.
Old Nov 2, 2007 | 10:25 PM
krm_wi_C5's Avatar
krm_wi_C5
I used the above Velcro and it has stayed in place for most of this year.
Old Nov 2, 2007 | 11:40 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Try 3M doublesided trim tape to hold the velcro on.
Old Nov 2, 2007 | 11:54 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
Depending on what you've used to clean your trunk hood inner surface you may have some residual preventing good adhesion. At first my velcro wouldn't stick worth a darn. I cleaned the surface where the strips goes with rubbing alcohol and they stuck without any problem of holding the liner in place.
To trunk liner help
