[Z06] Custom air intake
BUT!!!!....I would highly recommend stuffing some rags or something similar inside the filter before drilling. I failed to do that and now I will be cleaning out carbon fiber dust from inside the filter for who nows how many hours before I can complete the install.
Another thing to note - On the bottom of the filter, there is an open hole that is tapped for a 1/4-20 bolt. Be sure to screw a bolt in there to avoid having an unfiltered hole.
Last thing is to be sure to wear a good mask or respirator if you drill this thing. This stuff can seriously F up your lungs.
Is photobucket down or something? I can't see the pics so I posted the links also.
http://i69.photobucket.com/albums/i5...s/DSCF2437.jpg
http://i69.photobucket.com/albums/i5...s/DSCF2439.jpg
http://i69.photobucket.com/albums/i5...s/DSCF2441.jpg
I'm doing this purely for the cleaner looks and easier service. I ordered a new shroud to... should be very clean once all installed.
The rubber coupling is inside this sleeve, but it's not pictured here. You can see the tiny rivets I knocked out to free up the clamps:
http://www.acehardwaresuperstore.com...g-p-34919.html
Nice job!!!
I was worried about the carbon fiber cracking or shredding/tearing the fibers as well, but I went slow usinf my drill press and it never gave me a problem and the factory grommet fits perfectly.
-Deano (still 100% stock...
Need to pick up a replacement shroud too, another less desireable aspect of the Rammer. bob
Selling my BPP Vortex Rammer after 4 years. Theis K&N setup looks so much cleaner and will get just as much air w/ my TS facia (it'd get more than enough with the oem Z06 cold air screens) and being that I have no AIR it'll be simple and clean.
I ordered the 4" black coupler and some t-bolt clamps to make for a super clean install.
**There are a few factors to consider that really affect my ability to know what (if anything) I've gained by this install.**
Results: (on deserted rural backroad.
)** NO CODES **
Throttle response seemed a little "quicker" and the car really seemed to have more mid-range torque (especially in 3rd gear). Not sure if that was related to the filter install or the fact that it was 30 something degrees outside, but either way it was definately noticeable.
At any RPM, I could literally shred the tires off in second gear, even when squeazing into the throttle. Before I could only do that when jumping in it above 3500rpm. Once again, I'm sure air and tire temps had a lot to do with that too.
For less than a 100 bucks, I would definately recommend it. It is by far the best mod I've done to date (since it was my first
). Now I'm just waiting on a little warmer weather and better tires so I can get a better before and after comparison.
