I tried posting this in performance results and only got one reply, so I'll try it here.
I've searched for an answer to this and can't find anything, so...
I'm talking C5s here. Suppose you're doing a high speed run and you have a blowout or hit an animal or somehow get turned around. Does anyone know at what speed the car would fly going backwards? They have nice downforce going forwards, but I'm thinking that if you got turned around at some speed, the rear end would lift off...
Just curious... thinking about trying open road racing and am wondering what "could" happen...
EDIT TO ORIGINAL POST: I'm talking LEGAL high speeds at 150+... like you may see here:
I've never heard of anyone doing a study involving high-speed reverse direction airflow vs effects, but as everyone else would surmise as well....loosing it at high-speed such as on the Bonneville Salt Flats, you are going to be messed up if not terminal. The car wasn't designed for that direction at those speeds.
I've had a valve stem give way at high speed on my runflat (just about 80) and it was totally undramatic. I'd damaged it topping it off with air and hadn't realized. In fact the first I really knew of it was when the HUD/DIC warning went off giving a pressure low warning
By contrast, I had a tire blow out at 70 on an old Buick Le Sabre I inherited in TX. Now that was a different story but even then I didn't spin. Just a heavy pull; luckily into the edge of the freeway.
I guess if you run runflats you'd be more prone but a spin would be something else.
Assuming you're talking a closed course, (road racing would be dumb), I'd say the biggest risk would be a roll after a slide. To end up going bacwards would be a feat of driving.
To answer the point about airflow specifically, the design at the front is quite compex to get a smooth flow. There's no equivalent design points in the opposite direction so the rear of the car would act as a flat plate in aeroD terms. Goind backwards the flow would be all to pot so I guess it'd slow down pretty darn fast.
If you are worried about what could happen, I wouldn't go into open road racing. Lot's of variables come into play with any type of racing be it Drag Racing, Nascar, Indy, Etc... I am sure you have watched some of the crashes in racing before and have an idea of what is going to happen. It is very likely if you lose control of any car at a high rate of speed (150 MPH+) it is going to take flight. Just look at some of the dramatic Nascar crashes where the car lifts off the ground and flips many times. This is where Roll Bars and safety equipment come into play to help reduce the chances of serious bodily harm.
Not so much worried as being aware... yea, there are definitely risks, but I just like to be familiar with what they are as much as possible. The crashes that I've seen mostly in Nascar are what got me thinking about it... they have roof flaps and yet they sometimes take to the air, so I thought it might be an interesting discussion and maybe there is someone that has a story...
Having raced a few times at 150+ I would say that once you get out of line, you have just become a passenger.
I don't doubt that one bit... what type of racing were you at 150+? Any problems? I will eventually go to a track or closed course where I can do that, but to drive a timed event at those speeds would be thrilling!
Keep the discussion to legal racing.........all is well.......da rules
Not sure what you mean by this... I AM talking about "legal" open road racing - would never these speeds on the highway - although, apparently many have judging by other threads that I've read.
The mods keep a close eye on street racing threads and rightly so IMHO.
You're obviously thinking closed courses unlike some other posts recently
Ok, I see... I guess I should have mentioned that I was referring to legal racing in my first post. Thanks for the info - I'll remember that in the future.
