Opinions
Sure I would get like 45 days before either payment is due but I dont have a payment due till Feb 9 right now. I'm leaning towards the 07 Avalanche just cause I need a truck for work (30,000 miles per year). I miss my vette though.
Anyone wanna help a brother out?
Good luck though it does sound like a good car as long as you check it out like every one else is discussing. BTW mine does have memory seats but no HUD so it can be done but don’t know how common that is.
I'm still waiting for people's opinions on the Avalanche and/or vette. Post #21.
Remember my previous on this thread #14
Drive it and see how it runs out. Call the P.O. and ask about oil consumption. Early 01's had a problem that was corrected by the end of the year. I believe they did a recall and replaced the pistons oil ring. On average the problem cars would use a quart every 1000 K.
Check the drivers seat out. some of them had rocking chair syndrome due to the tracks loosening from the mounting bolts.
If it is an early 01 check to see if it has the column lock. If you can move the steering wheel back and forth with out the key in the on position its okay. If not ask the dealer if it has had a K harness install. If it is and early model and has the column lock it needs a CLB if it doesn't have one it will. If it is a late model there is no column lock in them.
Check for other signs of abnormal wear, tires. loose steering, rotton exhaust, loose, rounded, missing bolts in engine compartment.
Hope that helps some... Tux...
Isnt that a late year car?
I'm probably going to stick with a loaded 07 Avalanche LT with the 6.0 and heavy duty trans with HD cooler.
Guess they never learn Fined $188,000 for false advertising.
http://www.allbusiness.com/marketing...4149749-1.html
