Antenna Mod?
Old Jan 18, 2008 | 04:00 PM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
Default Antenna Mod?
I read in another forum that instead of buying a shorty, you can cut the existing antenna down? is this correct does anyone have the info on doing this ? i did a search but no luck, how short would i be able to go without losing quality reception? thanks
Old Jan 18, 2008 | 04:05 PM
hotwheels57's Avatar
hotwheels57
It's easily done if your antenna is a fixed mast. Optimum reception comes from a vertical mast of approx. 36".
If that's not important to you and/or you live in a metro area with good reception, simply cut off the amount you want to remove with a fine toothed hacksaw and fit a 1/8" vinyl cap to the end.
How much you should cut off will vary depending on your specific location in relation to transmitting towers.
If you listen only to CDs, you can leave the fixed mast off entirely and just add a vinyl cap over the threaded boss.
Old Jan 18, 2008 | 04:23 PM
Janfun's Avatar
Janfun
Why would you save a buck and cut the antenna when you can buy a shorty for $25???
This one is shortest that I know:
http://www.southerncarparts.com/corv...nna-p-480.html
Anyhow you already seem to have all the answers from Z06 forum so good luck.
http://www.z06vette.com/forums/f5/antenna-108891/
Old Jan 18, 2008 | 04:24 PM
BitViper's Avatar
BitViper
Yeah what he said...cut it a multiple of its full length that way wavelenght wise your in the ball park
Old Jan 18, 2008 | 04:36 PM
ZEEEEOOOOSIC
From what i have read from forum members and seen for myself in person the quality on that antenna is very poor plus quite fugly i would rather have the stock just shortened no one said anything about saving a buck its more about looks
Old Jan 18, 2008 | 04:51 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi ZEEEEOOOOSIC -
I shortened mine down to 9" and the reception is not changed from when it was the stock 10 feet tall.
I pulled the anti-static ball off the end - cut the antenna shaft down to 9" and then used my dremel tool to carefully grind down the tip of the resulting shaft so that it made a good interference fit into the anti-static ball.
I also put a dab of silicone to help the ball adhere to the shaft.
Then I hit it with from black paint and put the antenna back on.
And - FYI - you can buy an antenna from GM for under $10 if you want to retain the stock one for the year 2060 for Bloomington Gold certifications.
This link shows a picture of how the antenna looks on the car - not a close-up.
http://www.iammoon.com/albums/Corvet.../DSC00558.html
best regards -
mqqn
Old Jan 18, 2008 | 05:49 PM
ZEEEEOOOOSIC
Thanks mqqn! i will go with the same height just what im looking for, by the way eb rocks baby
Old Jan 18, 2008 | 06:00 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi ZEEEEOOOOSIC -
Thanks!
No problem!
To pull the anti-static ball off, I used a rag and some vice grips, but in retrospect, It might have carefully used a razor to try to score the black epoxy coating on the antenna where the ball and the shaft come together to make the ball release easier - and thus not require a death-grip on the ball that may put teeth-marks on the ball.
Good luck!
best regards-
mqqn
Old Jan 18, 2008 | 06:40 PM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
I don't understand why someone doesn't make an antennae that goes underneath the rear bumper. Something like a window antennae.
Old Jan 18, 2008 | 07:23 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Though I'm tempted to put a shorty antenna on my 'vert, what I ended up doing is wiring a on / off toggle switch to my stereo since the 'powered amp' line t's off onto the 'powered antenna' line. I listen to my mp3 cd's most of the time anyways so I just leave the antenna switched off; on the rare occassion I listen to the radio, I usually get satisfactory reception even with the antenna down.
Old Jan 27, 2008 | 11:50 AM
BitViper's Avatar
BitViper
Or one of these....
PM me for info
Old Jan 27, 2008 | 11:54 AM
DeeGee's Avatar
DeeGee
They make one that hides under the fender
Old Jan 28, 2008 | 10:17 AM
BitViper's Avatar
BitViper
cuz outside of an electric..you'd have a hole you'd have to fill
Old Jan 28, 2008 | 01:10 PM
burbleflyer
St. Jude Donor '08
That's what I put on mine when some asshat broke off my shorty.
With a plastic rear facia you should be able to get an antenna to work inside.
To Antenna Mod?
