Rotor rust
Old Jan 23, 2008 | 11:57 AM
shaggyboiler's Avatar
shaggyboiler
Default Rotor rust
So at the end of the summer I bought some new brakes, calipers and roters. Was in dire need of breaks and rotors. I bought some AC Delco Cross Drilled rotors. I didn't know at the time the problem they had with rust. After about the 3rd car wash (by hand) I noticed the hats and outside edges of teh rotors had rust on them. The rotor itself did too but that disappears fast with one quick stop.
So now I'm trying to figure out what to do. Since the rust is there.
Any ideas?
Old Jan 23, 2008 | 12:01 PM
jrprich's Avatar
jrprich
There are several Rust Eater products that you paint on and they bond with the rust and prevent it in the future. Then you can paint over it.
Old Jan 23, 2008 | 12:19 PM
krm_wi_C5's Avatar
krm_wi_C5
You can take them off of the car and have them zinc dipped. There is probably a local place that does this. I also put new rotors on my car last year, mine were zinc coated and there is not a hint of rust on my rotors. Mine are Baer Rotors.
Old Jan 23, 2008 | 12:21 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Your best bet is "zinc" coated in the future, but since you've already made your purchase, you could try what 'jrprich' suggested. Good luck...
Old Jan 23, 2008 | 12:42 PM
jarsdad1's Avatar
jarsdad1
or you could buy some rotor "hats" and use them now. When it's time for new rotors you can go zinc and sell the hats to someone.
Old Jan 23, 2008 | 12:50 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
I used a rust remover, then painted the outside rim of the rotor and put paint in the drilled holes. Then put chrome rotor hats on. (hats not on in photo)
Old Jan 23, 2008 | 01:18 PM
Junkman2008's Avatar
Junkman2008
I rust treated the crap out of mine and then painted them with rust proof paint. Almost 6 months and a thousand washes later, no signs of rust except where the brake shoes ride after a wash. As you stated, that disappears after the first stop. Notice how thick the paint is on the edges. I gunked it on real heavy so that no rust would ever show up there again.
Old Jan 23, 2008 | 01:33 PM
Oldvetter's Avatar
Oldvetter
Clean with brake cleaner. Paint them with high heat (1200 F) Rusteolum Paint. I used silver/aluminum. Paint the top hats (tape lugs), disk edge (no need to mask), holes, and vents (edges). Did several years ago, still good.
Old Jan 23, 2008 | 01:40 PM
RobertEarl's Avatar
RobertEarl
Just out of curiosity, why in the world do you care.
Old Jan 23, 2008 | 01:48 PM
shaggyboiler
I care cause it really looks bad with my yellow calipers and thin spoke rims to see rust on there. Soon as it warms up a little. I'll pull the rotors off the car and use some rust remover and paint them with high temp paint.
Old Jan 23, 2008 | 02:03 PM
Junkman2008
It looks nasty. Really takes away from the wheels.
Old Jan 23, 2008 | 02:11 PM
JCMVette's Avatar
JCMVette
When I have to change the brakes I will buy zinc coated rotors.
Old Jan 23, 2008 | 02:15 PM
Vert'd Z0's Avatar
Vert'd Z0
Default same problem........
^ so i did the same thing as oldvetter (but with satin black). my first thought when i bought 'er with the ac delco's was i would quickly replace them with some baers. but with the mod money going towards the CCW's and tires, it wasn't going to happen for a while. but after i mounted up these friggin' beautiful larger wheels, the rotors stood out lke a sore thumb. so i just took a wire brush on a drill to the rust, cleaned 'em all up and followed up with the hi-temp paint. looks great and allowed me to spend my "rotor" money on other things.
Old Jan 23, 2008 | 02:57 PM
bucwheat's Avatar
bucwheat
Clean painted rotors look awesome.
Old Jan 23, 2008 | 03:14 PM
jrprich's Avatar
jrprich
[QUOTE=Junkman2008;1563761175]I rust treated the crap out of mine and then painted them with rust proof paint. Almost 6 months and a thousand washes later, no signs of rust except where the brake shoes ride after a wash. As you stated, that disappears after the first stop. Notice how thick the paint is on the edges. I gunked it on real heavy so that no rust would ever show up there again.
[QUOTE]
Bout time you cleaned up those rusty rotors
Old Jan 23, 2008 | 03:29 PM
Dave68's Avatar
Dave68
Actually, you'd be much better off with cadmium-plated rotors.
Zinc is a very soft metal and at the thickness typically applied, is fairly flimsy in the long run. cadmium is much harder and more durable, even compared to an epoxy-based paint.
All PowerSlot rotors are cadmium-plated. Yes, they are more expensive than zinc-washed rotors, but the cad-plated rotors will look good far longer.
Old Jan 23, 2008 | 04:06 PM
Slow Z06's Avatar
Slow Z06
I Think You Should Stop Driving It Imediatly. Bring It To Houston, And Ill Take Care Of It For You
To Rotor rust
Old Jan 23, 2008 | 06:29 PM
JEEP/C5's Avatar
JEEP/C5
How could you not care? If you have to ask why then I would ask you "why do you drive a corvette?". If you dont care about the looks of your ride then drive a Pinto. For many (most) Corvette owners - looks are everything on our cars. Not trying to be a smart@ss but I was kinda shock that you even asked that question.
Or perhaps you wanted this type of reaction?
Old Jan 23, 2008 | 07:37 PM
RobertEarl's Avatar
RobertEarl
I bought mine to drive not to wash and wax. It is my daily driver along with many autocrosses and HPDE. Evidently, I care as much about driving mine as you do washing yours. Just different tastes. I like to use what I buy, not just look at it like a women with a diamond.
Old Jan 23, 2008 | 07:48 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I too went the Delco route for d&s rotors about 6 months ago. it didn't take long for them to look like crap. mostly hidden by the wagons I lived with it but I knew when I decided to switch to C6 wheels all that rust would show. I got the unfinished hats from Ecklers and painted them high temp black and painted the edges with Bill Hirsh's cast iron exhaust manifold paint. while at it I painted the calipers black also. the holes and slots are still rusty but the pad dust usually covers it. to do over I'd go plated....... live and learn
