Gasoline
Old Feb 9, 2008 | 11:22 AM
taggie's Avatar
taggie
5th Gear
Default Gasoline
I'm in California and I've been told that because of environmental laws in my state the gasoline is much higher quality and as a result high performance cars like my 2001 corvette do not need 91 octane. Is that true?
Old Feb 9, 2008 | 11:25 AM
DeeGee's Avatar
DeeGee
Stand by for a variety of answers
This subject always generates a lot of debate.
The owners Manual actually says:
“Fuel - Gasoline Octane
Use premium unleaded gasoline with a posted octane of 91 or higher for best performance. You may also use middle grade or regular unleaded gasoline rated at 87 octane or higher, but your vehicle’s acceleration may be slightly reduced. If the octane is less than 87, you may get a heavy knocking noise when you drive. If it is bad enough, it can damage your engine.”
E-T, who was involved in the design of the C5, will post an explanation of why the high compression of the LS1 needs good gas (he says 91 minimum and 93 if you could get it). It has a knock sensor which automatically retards the ignition if it senses knock. If its doing that, by definition you have less power and lower fuel efficiency.
In my book, although it may protect the engine to a certain degree, it’s still a compensatory adjustment. In other words it’s solving the problem after the event so some damage could occur however slight.
For a couple of cents a gallon, I won't take the chance. JMHO
In UK Regular gas is 95 octane (RON) which equates to 91 octane in the US. The Super Unleaded is 98 octane which is about 93/94. I use the Super when I can get it but not all gas stations sell it here.
Old Feb 9, 2008 | 12:25 PM
02MillenniumVette's Avatar
02MillenniumVette
I have to use premium because of the compression that Im running but if you car is stock you can run on regular and middle grade. Personally, Id rather spend the extra $3.00 and get premium, since thats about all you are saving.
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Octane is octane, If you are around sea level that is the more reason to use 91 or 93.
JMO.
Bill K
Old Feb 9, 2008 | 12:47 PM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
JMO.
Bill K
Old Feb 9, 2008 | 12:59 PM
Gonzo's Avatar
Gonzo
Good answer
The person that was telling you this may be confusing Octane ratings with some type of environmentaly friendly thing Ca. may require in the gas to reduce emissions, but 91 octane should be the same in Ca. or Ga.
Old Feb 9, 2008 | 01:23 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
JMO.
Bill K
Well being my "summer house" (that we go to every weekend)has a deck..."on the beach" and according to google earth... I am 3 feet above sea level I guess its good that I use Shell super 93 huh?
Old Feb 9, 2008 | 01:34 PM
Husker67's Avatar
Husker67
I did not know anything existed in California that would be considered high quality, other than fruits and nutcases!
Old Feb 9, 2008 | 01:36 PM
Mr.Bill's Avatar
Mr.Bill
Now that is just wrong. You have a lot of brothers and sisters from there.
Old Feb 9, 2008 | 01:38 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
California gas? Gas can vary in quality, but not from what state it's dispensed from. (In less there's a state not blending 10% ethanol)
Old Feb 9, 2008 | 01:44 PM
DeeGee's Avatar
DeeGee
Originally Posted by Gonzo
Good answer
Except here in UK where we use RON not PON or MON. 91 PON (US) = 95 RON (UK)
Confused.... Oh boy
I think you may be right though
Old Feb 9, 2008 | 05:49 PM
Gonzo's Avatar
Gonzo
Confused.... Oh boy
And I was going to start importing gas from you
But now that I know that, I think I need a "Pint", not a liter or gallon
Old Feb 9, 2008 | 05:59 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
"Quality" vs. Octane.....
It's ALL about the octane rating.
As said before, the higher the octane, the greater the resistance to combustion due to compression only. You want the spark to start the power stroke, not the compression alone.
High compression engine needs all the resistance it can get.
Don't skimp on your fuel just to spend it later on repairs....or bus fare.
Old Feb 9, 2008 | 06:03 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
I drive my '01 on regular most of the time. On occasion I'll get "the good shtuff" (91) when the price is right, and I will definitely see some improvement in acceleration and performance, but not enough to warrant the extra cost every time I fill up. I'll usually only pay the extra amount when I know I'm going out on a cruise or doing something more than using it as a daily driver.
Old Feb 9, 2008 | 06:49 PM
ZNFUL-Z06's Avatar
ZNFUL-Z06
Octane is octane quality and drivability have nothing to do with it... different test methods measuring differrent characteristics of gasoline
Old Feb 9, 2008 | 06:52 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
JMO.
Bill K
Old Feb 10, 2008 | 12:06 PM
taggie's Avatar
taggie
5th Gear
Default gasoline
Thanks for all the info! I think I'll stick to the 91.
To Gasoline
Old Feb 10, 2008 | 12:09 PM
LEANDRO's Avatar
LEANDRO
This is a corvette not a ford escort. Use the good gas
Old Feb 10, 2008 | 01:42 PM
ljthe2nd's Avatar
ljthe2nd
The way I look at it, if you can't afford a few cents more a gallon to make the car perform the way the factory built it to perform, you can't afford the car. Go buy an economy car, but that's just my opinion. Buy 91 octane or higher.
Old Feb 10, 2008 | 02:25 PM
b98's Avatar
b98
JMO.
Bill K
Not here in TEXAS, we get the good stuff, the rest of the country gets, well lets leave it at that.
